Question about Venom Group International Green Venom Micro Ranger Mini Indoor Electric RC Helicopter Infrared Remote
How do you get to the wiring on micro ranger venom there seems to be a loose wire but we dont know how to get to it.
    Brigadier General:
  • 3,917 Answers
95 ford ranger has been burning up starters every year all wires and conections relays have been checked out all good . when starting all i get is a click and then my power locks go up and down a couple...
It may be a loose connection on the big wire from battery to the starter and - or negative to battery. A volt meter should be used to test for power and excessive voltage drops. I would suspect a wire terminal to wire.
Aug 24, 2017 | Cars & Trucks
My boys have a venom micro troop transporter helicopter, serial #2650915228A. Lately, when the copter is more than 8 feet from the controller the copter dies. Is there any way to increase the range?...
Hi
The range itself is configured in the electronics and controlled by the FCC. The most common problem here is the transmitter batteries are weakening or are those clone type batteries. If you can find them, Fuji makes the best batteries for RC electronics. Good luck
Jul 08, 2010 | Venom Micro Rescue Helicopter Ready To Fly
My 98 ford ranger shuts off when i turn to the right
Does it just kill like you shut the key off ?
If so I would say you have a loose wire or shorting wire in the ignition , that when you turn the steering wheel to the right( the side the igniton tumbler is on) it is catching a wire or shorting.
Please let me know what you find.
Feb 08, 2010 | 1998 Ford Ranger SuperCab
1989 Ford Ranger... I added a can of seafoam, changed the fuel filter and spark plugs and it still runs horrible. I dont know what else to replace
Try to remove each plug wire one at a time while the engine is running to see if it makes a difference. If it does , it's prolly an injector. It could also be a plug wire
Sep 03, 2009 | 1989 Ford Ranger
Have replaced bulb on front back bulb is ok works some times some times not
several things, see if bulb is loose in socket, check connector, look at wires and see if insulation has rubbed through and is shorting,
if wire insulation is worn and can see wire tape it, if bulb is loose pry pins in just a little if socket is loose or dirty clean and apply little dielectric grease (from auto store). this should fix it
Jul 09, 2009 | 2002 Ford Ranger Regular Cab
Dont know correct placement of spark plug wires
try here...
http://autorepair.about.com/library/firing_orders/bl-ford-firing-03.htm
Apr 22, 2009 | 2003 Ford Ranger Regular Cab
Problems with 94 Ford Ranger
Sounds like corroded ground wires. Locate the ground wires to chassis and body, if they appear rusty or loose, clean with wire brush and liquid wrench and tighten them well.
Mar 09, 2009 | 1994 Ford Ranger Supercab
Wiring Diagram for 2005 Ford Ranger XLT
I have wiring diagram. Respond with your email address or fax number and I will sent it to you.
Sep 18, 2008 | 2005 Ford Ranger
Hi i have a question
you need to get a used one out of a junkyard and just reconnect the wires. alldata also has a great site for wiring
Sep 10, 2008 | 1992 Ford Ranger
Venom Group International Green Venom Micro Ranger Mini Indoor Electric RC Helicopter Infrared Remote Logo
132 people viewed this question
Top Venom Group International Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Venom Group International Toy Expert? Answer questions, earn points and help others
