Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
How to Clean Dyson DC 32 Vacuum Cyclone Component
  • 389 Answers
SOURCE: Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Posted on Apr 09, 2009
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
  • 4 Answers
SOURCE: How do I dmantle the Cyclone?
You don't! It is not meant to be dismantled. Just pour water inside it. Then let it dry out thoroughly, say, 3 to 4 days, including the filter.
Posted on May 30, 2009
  • 8 Answers
SOURCE: My dyson dc 24 just stop picking up. There is a
Check to see if the brushes on the bottom are turning if not change the vacuum belt.
Posted on Sep 13, 2009
VacuumRepair
  • 438 Answers
SOURCE: I need the user manual for the vacuum Dyson
The Dyson DC23 Animal owners manual was extremely difficult to find! I was able to find it for you however.
Please visit the link below, and just give it a minute or two to load. I was able to download it, and I did verify that this is the Dyson DC23 instruction booklet.
Owners Manual For Dyson DC23 :
http://media.dyson.com/downloads%5CAU/floorcare/manuals/DC23_AU_opManual.pdf
I hope that this helped you! Please be sure to rate my repair as helpful if this helped. This is what really keeps Fixya experts continue giving free technical support and keep coming back. Thank you for this kind gesture. If you have any questions please feel free to add a comment here on the repair page.
Thanks,
Chris J.
GoVacuum
Posted on Apr 07, 2010
Animal Pro DC 54. Can I rinse the filter?
Hi there, it's Jack at Dyson.
The Dyson Cinetic DC54 has no filters to wash, replace or maintain. It's not necessary to maintain the cyclone pack either - it's very important not to wash or submerge the cyclone pack as this can cause damage to your machine that wouldn't be covered under the Dyson guarantee.
It's normal for harmless static to cause fine dust particles to cling to parts of the clear bin and cyclone pack after use. This won't affect performance as airflow doesn't need to pass through this dust, as it would with a traditional bagged or filter-based vacuum. The oscillating Cinetic tips ensure dust and allergens are separated from the airflow and thrown into the clear bin.
When you empty your machine, tapping the cyclone pack firmly will help dislodge any clinging dust particles. Any clinging fluff or debris can be removed from the stainless steel mesh shroud using a soft brush or a dry cloth:
dyson-animal-pro-dc-54-rinse-out-filter-kfbnp2bw3njuiocelunhji5a-2-0.jpg Please do not clean the cyclone pack in any other way as you could risk causing damage.
I hope this information helps, but if you'd like any additional guidance you're welcome to get in touch with our experts directly. You can reach the Dyson Australia team by calling 1800 239 766.
Feb 20, 2016 | Dyson Vacuums
How do I take the drum of a dc33 to wash it
To remove the clear bin, first separate the clear bin and cyclone pack from the vacuum cleaner. Press the trigger to open the bin base, as if you were emptying the machine. Then with the bin base still open, press the silver catch on the rear of the cyclone pack to remove the clear bin.
You can then rinse the clear bin in cold water without detergent, or wipe it using a damp cloth. Make sure it's completely dry before reassembling the vacuum.
Please note, the cyclone pack should never be washed or submerged as this could cause damage not covered under guarantee. You can use a soft brush or a dry cloth to remove any fluff or debris from the shroud.
If you'd like further help or guidance, you're welcome to contact the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 23, 2015 | Dyson DC-33 MultiFloor Upright Vacuum...
Dyson Dc07 Animal Cyclone Assembly will not release bin
I would highly recommend that you contact Dyson directly before you go breaking anything else. Good Luck!
Contact us
The Dyson Helpline is available during the following times (CST):
Monday - Friday: 8am - 8pm
Saturday: 9am - 6pm
Closed on Sunday
Aug 30, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Dc 54 how to open bin
Once you've removed the clear bin and cyclone from the main body of the vacuum, the red button on the cyclone top will open the bin base. This diagram should help:
Our Getting started video guide also shows how to remove and empty the bin after use:
I hope this helps, but if you'd like any further advice you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 24, 2014 | Dyson Vacuums
When cleaning the cyclone head can this be flushed with water?
Hi Len, it's Jack at Dyson.
The cyclone pack on your DC14 should never be washed, flushed with water or submerged. Any residual water left within the assembly could cause permanent damage to your vacuum not covered under warranty. It could also contribute to an unpleasant odour from your machine in use.
To clean the clear bin and shroud, you can remove the clear bin from the cyclone pack using the catch on the rear of the cyclone pack, as shown below. A soft brush or dry cloth can then be used to remove any clinging fluff or debris from the shroud. Gently tapping the cyclone pack will also help remove any clinging dust particles.
You can also rinse or wipe the inside of the clear bin with a damp cloth to remove any dust particles, but make sure it's completely dry before reassembling.
I hope this helps, but if you'd like any further guidance on maintaining your vacuum, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
I have just brought a Dyson DC 07 from an auction . It seems ti have a blockage or somthing in the8 cyclone part
Hi its Darran at Dyson.
With the bin separated from the cyclone top, try lightly banging the side of the cyclone top while holding it over a bin. This should remove any dust or debris caught inside.
If this doesnt clear it a replacement cyclone top can be purchased direct from Dyson via www.dyson.com.
Kind regards
Darran
Dyson Customer Liaison
Mar 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you clean out the cyclones on the Dyson?
http://www.ehow.com/how_5028186_clean-dyson-dc-cyclone-canister.html Just followed the procedure and it works great. A little messy and the canistar seal was tough to break apart, but it worked fine.
Oct 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
May 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
1,782 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
