Question about Kenmore Washing Machines
I have a kenmore elite washer - not sure of model. It is about 6 years old. Today we noticed oil in the area where the fabric softner goes as well as oil on the rim of the washer. What would you recommend. Seems like a pump seal or bearing has failed. Is this something I can fix myself or do I require a repair man?
  • 54 Answers
Go to the Sears website. They have a very nice parts search database, complete with schematics and drawings for the vast majority of their appliances. With that information, you may be able to determine what could have failed, and whether or not you are up to the challenge of fixing it yourself.
Posted on Sep 15, 2010
My top load Kenmore Elite Oasis which is 3 years old leaves particules that look like grease from the fabric softner on my clothes after being washed. Is there a way to clean out the residue left from the...
Kimberly,
I would use Dishwashing detergent and hot water, (not dishwashing Soap - different). The detergent is low sudsing and will help remove the softener, but it must have Hot Water to work. For the future you will need to dilute the fabric softener with water to prevent it from building up.
Good Luck
Sep 10, 2011 | Kenmore 22422 Top Load Washer
I have the Kenmore Elite Gas Dryer (not steam). I
Take pantyhose around the inside and see if it catches.
Pay particular attention around the drum/door area.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite spraying fabric softener all over clothes and tub
hello mam
is this softner provided by the kenmore dealer if not please getit from them because they know whish softner should be used and for the spots use descaling powder and run the machine without loading clothes.
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Oil on clothes front loading kenmore washing machine 7 years old
Oil cannot get on clothes from a front loader . It's probably the liquid fabric softener you are using . Either try a different brand , use dryer sheets instead , or make sure the water temperature is correct for the softner . Also check the front drum seal , for built up , undisolved softner , collecting " gunk " which may be getting on the clothes .
Sep 16, 2009 | Kenmore Washing Machines
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Kenmore Elite Oasis, fabric softer thing exploded...
Okay...the cone actually goes inside the the two other pieces you mention. The cone is to be inserted upside-down. That is, the opening of the cone should be facing UP. The way this fabric softener dispenser is supposed to work is, you place fabric softener thorugh the opening of the dispenser. The cone actually holds it like a cup. When the washer goes through the initial spin cycle before the rinse cycle begins, the centrifugal force of the washer spinning forces the fabric softener out of the cone and into the wash tub.
The dispenser assembly should just snap right on top of the agitator. If the dispenser does not stay on securely any longer, you may have to replace it with a new one. You can find replacements at searspartsdirect.com. Just type in the same model number you provided and look for item number 1 under the "Motor, Basket and Tub Parts" heading.
I hope you find this information helpful. If you still have questions, please let me know.
PS It is also a good idea to periodically remove the dispenser and soak it in some hot water to get rid of accumulations of hardened softner. They will clog from time to time.
Sep 04, 2008 | Kenmore 24032\24036 Top Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
