Question about Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer
I have a Maytag Bravos Steam dryer with the glass door. The door will not stay shut and I am tired of using tape. What can I do to fix it?
  • 23 Answers
What is the model number of the actual unit, It may be the door seal or boot causing the problem,
Posted on Sep 15, 2010
What should the door glass orientation be?
Type Maytag dryer door glass installation into YouTube and see what comes up, thanks!
Aug 01, 2015 | Maytag MGD5100DW MGD5100DW 27" wide 7.4...
Why won't the dryer door close? Little attachment on door is rattling
Type Maytag Bravos door problem into YouTube and see if the video comes up, thanks!
Jun 23, 2015 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Ma secheuse maytag ne fait pas de vapeur
translation
My Maytag dryer does not make steam
Permalink
When I put on this function makes no steam
questions
1. is there water flowing to the dryer?
2. Is the dryer connected to a water source
3. Are there any clogged water filters or screens in the back of the Dryer.
4. If there are no water problems, then I would check for thermal fuses or defective control boards.
Oct 30, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Need to remove the glass lid to get to an area of rust caused by a maytag technician chipping the paint and they won't fix it
Tape the washer lid closed. Using a putty knife, press and unlock the two front top locks. The locks are approximately six and a half inches from the outside edge of the washer
Mar 10, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos 400 series with steam Dryer
You might have a shot motor, or a fault in the wiring inside the dryer. Have a tech test both.
May 08, 2012 | Maytag Dryers
Maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
May 02, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer door won't shut
you will have to adjust the catch to line up and secure it ,
good luck !
Jan 27, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
362 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
