Question about Remington Precision Deluxe PG-200 Beard Trimmer
Can i replace the battery on the pg-200? - Remington Precision Deluxe PG-200 Beard Trimmer
What model/type of battery for gillera st 200
Are you talking about a Gilera Runner ST 200? I'm not familiar with a mobility scooter by the name you mentioned. If you do mean the Gilera ST 200 you can find a replacement battery and info on the battery itself on Amazon.
Piaggio Gilera 200 Runner 200 2010 2012 YTX12 BS Sealed Maintenace Free...
Jan 14, 2015 | Health & Beauty
PG UP ERROR IN NIKON D 200 CAMERA
Is this a D80 or a D200?
If you had a failure during firmware upgrade, then your circuit board is trashed. Send it to Nikon - it requires software to replace.
Mar 18, 2013 | Nikon D80 Digital Camera
Remington pg200 groomer disassembly
This is a very simple repair.
To disassemble, twist the round bottom part (with the battery contacts) counterclockwise just a bit. Use jaw pliers if it won't twist with your hands alone. To protect the plastic finish of the groomer use some duct tape or a rag on the jaws. Gently twist and open the assembly. When separating the bottom part, take care not to pull it apart too far from the main assembly to avoid damaging the 2 thin wires connecting the bottom plate on the inside of the bottom charger to the main body of the groomer. The batteries will just slide out easily; they are not soldered or attached in any way. You can replace the batteries with any two standard AAA rechargeable NiMH batteries (1.2 volt).
Since the batteries are so easy to access, and there is no solder involved, in a pinch you can even use regular AAA Alkaline batteries! (but, of course, NEVER USE THE CHARGER WITH NON-RECHARGEABLE BATTERIES!!)
The groomer is now as good as new!
Dec 08, 2012 | Remington Precision Deluxe PG-200 Beard...
I lost my power supply adapter/transformer....there is no manual....what size do i need for the adapted/transformer
The last item on this page is the user manual for the Xantrex 300
http://www.xantrex.com/power-products-support/document-downloads/discontinued-products/discontinued-products-backup-power.aspx This is a pdf. Right click, and "save as"
I would suggest it will be almost identical to your 200.
From personal experience, I imagine it uses 12volt lead acid sealed cells, Typically this would use a 13 to 14 volt powersupply probably at 2.5 to 3 amps.
You can also charge the device from your cig lighter socket. See pg 16 of manual.
Jan 16, 2011 | Xantrex Technology XPower Powerpack 200...
Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Nov 17, 2007 | Remington Titanium Precision PG-300 Beard...
Remington Precision Deluxe PG-200 Beard Trimmer Logo
134 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
