Question about Refrigerators
Water dispenser not working - Refrigerators
  • 10 more comments
  • Anonymous Nov 24, 2008
    I also have this problem! We thought it was the filter, so we replaced that. However, it's still not working. The ice maker works, so I know there is water flow. Is there a reset button or something?
  • qurong2003 Dec 06, 2008
    I have same problem. Ice maker works fine, but no water.
  • Anonymous Jan 06, 2009
    Having the same problem. Ice maker works fine, but can't get any water.
  • Fixya261 Jan 08, 2009
    I have the same problem - my fridge is 8 years old. Ice maker works fine, changed the water filter and still no water or just a dribble. I don't hear it trying to work either.
  • gutterman13 Jan 22, 2009
    I have the same problem ice maker works fine but no water.
  • Anonymous Mar 24, 2009
    GE GSH25JSRFSS water dispenser lines appears to be frozen; ice dipenser works.
  • Anonymous Apr 01, 2009
    water dispenser does not work ice does come out though
  • Anonymous Apr 04, 2009
    58585 Water dispenser stopped working. Ice maker works find, please help !
  • Anonymous Apr 06, 2009
    The water dispenser doesn't work,but the icemaker is fine. When I depress the water button it acts like it wants to work but nothing comes out.
  • Anonymous Apr 19, 2009
    Samsung side by side refrigerator
  • lubritech May 06, 2009
    ice maker works fine and water dispenser sounds like it wants to work. is this a air lock issue? how do i fix?
  • tandckurbis May 14, 2009
    Same problem - there is water to the bottom of the freezer door, and pump starts when switch is pressed, but no water is dispensed. i'm assuming a frozen or plugged line, but don't know how to check or solve if it is. Ice dispenser and maker is working fine.
I have a ge profile artic and the water dispensor button does not work, it won't click on or anything, the Ice dispencer works fine. what can I do?
Posted on Mar 31, 2009
    Problem Solver:
  • 5 Answers
To fix it turn your freezer temp higher, it shouldnt be below -16 if it is, the water freezes and then you dont get any water, the best thing to get your water flowing again it turn off the freezer and leave the door open for a few hours so the ice that has formed in the water pipe can melt.
Posted on Jul 27, 2010
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
My water dispenser in my GE Adora stainless side by side refrigerator is not working
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | Refrigerators
Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Refrigerators Logo
3,882 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
