Question about True T23 Refrigerator
Will not maintain 40 degrees. continues to cool until everything inside is frozen. temp gauge reads 10 degrees.
  • 54 Answers
Sounds like a bad thermostat.
Posted on Sep 15, 2010
How do you put in 410a into Ac unit
You turn system on to cool setting and run temp down until outside unit comes on. Then you connect your suction side of your gauges to the suction side of your outdoor unit. Next you connect the liquid(high)side of your gauges to the liquid line on your outside unit(the little copper line). Connect the middle hose of your gauges to the 410a drum of refrigerant. Before opening the suction or low pressure side of the gauges you need to turn the drum upside down and turn drum of 410a on. Then you need a temp reading meter and clamp to read the temp of your liquid line(small line). While charging you want to make sure to release refrigerant slowly. The unit should call for a specified subcooling on unit plate. 7 to 10 degrees. You take the liquid line temp and subtract it from saturation temp on the high side of your gauges.(it'll be the pink numbers on the right side of your gauge.
Jun 05, 2013 | Heating & Cooling
Why does the freezer portion temp indicator bounces between 0 and -12 degrees periodically.
Temps should fluctuate, as the refrigerator will go into a defrost mode every so often. Some models will go into defrost mode after you open the freezer door X amount of times, say 6. So every 6th time you open the door it will go into defrost. Then some models go every 4 to 6 hours depending on settings. Then also, it is normal due to temp control. Temp setting is -10 The fridge will run to that temp setting, -10 and shut off the compressor at -10 but due to pressures it will still cool a bit to your -12. it will stay in this off mode until the temp rises 8 to 10 degs. then kicks back on the compressor. Again due to pressures it may take the system 2 - 3 degs to catch back up and start cooling again. But you maintain average temp of -5 to -6 which is great for frozen food and saves a bit of electricity. As long as the door seals are in good shape and you clean the coils underneath once twice a year it should work fine for many years. Then lastly It may have a lag in the thermostat meaning it has gotten week or going bad. Hope this helps.
Jan 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a used Tappan gas range with 4 burners and a griddle in between the burners. everything works, but the oven temp varies about 40 degrees above and below the setpoint. it never seems to level out...
not normal
problem thermostat not lighting the gas or turning the gas off to maintain an even temp
temp variation should be around a 10 degree range
call a gas fitter to check out the oven controls , thermostat or thermocouple
Sep 19, 2017 | Tappan Kitchen Ranges
2000 Dodge Caravan 3000CC engine - In summer, temp gauge in the center. Water temp is 190 degrees. In the winter, temp gauge at quarter level. It takes forever to rise. If you use the heater, the temp in...
Sounds like a stuck thermostat. The thermostat cycles open and closed in order to maintain a temperature range, some cars with very sensitive gauges reflect this opening and closing, but most cars have gauges that are somewhat less responsive in order to keep people from thinking something is wrong. I would defineately replace the thermostat and flush the cooling system, replacing the fluid with fresh.
Dec 22, 2009 | 2000 Dodge Caravan
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Friar heats up to correct temp but doesn't maintain
The first thing I would check is the hi limit.If that not out then I would try to a temp. gauge that will read above 350 degrees.maybe the thermostats is not right. Reading to low for the temp.
Mar 13, 2009 | Pitco Frialator 35CD Deep Fryer
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Fridge part not cooling properly
Miss Sugarbaker, it almost sounds like a airflow issue, but check to see if the interior light is going out when the door is shut. This would cause the higher temps on the top shelves. The damper assy. is controlled by a thermistor that sends the temp info to a main board in the back. If this thermistor is bad, the damper will not funtion properly. Catriver..post back.
Sep 27, 2006 | Hotpoint HSS25GDMWW Side by Side...
True T23 Refrigerator Logo
212 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
