Question about Sony VAIO VGN-CR320ER Notebook
I have a problem fan is not working well but fan is ok
  • 128 Answers
Trying cleaning it out with air.
Posted on Sep 15, 2010
Engine fan
test the fan for proper function if its burnt anything you do will not make it work so jump power wires to the fan to see if it works you also have a temp sensor that might make the fan work as well if its defective does the temp in the car go up if you have a guage on the dash or a light comes on hot so 1- fuse ok 2- relay is a good working 3- connector at fan ok 4- fan motor working by jumping wires easy to follow diagnostics
May 28, 2014 | Mazda 323 Cars & Trucks
1985 new yorker cooling fan won't operate.
could be a bad coolant tempurature sensor if radiater cooling fan does not work, or a bad relay for fan in fuse box for the fan.. if all is ok ! disconnect fan at the connectors. on the motor side, run a wire from positive on battery, to pos itive fan motor. ground other wire to negative on battery. if the fan works its ok. good-day ! check relay and fuse for the fan first.
Feb 01, 2012 | Dodge Vehicle Parts & Accessories
Air condition and fan dont work
If all fuses are ok then check wiring to fan and compressor both, if wiring is also ok and current is passed till the terminals then you have two problems, one the magnet forming coil on the compressor head is burnt, you have to replace or get it repaired. second your fan itself needs checking.
Jun 05, 2010 | 2003 Honda Accord
The only speed on my heat/air fan the will work is high. All other speed quite at the same time. Would this be the fan motor or could it be a fuse?
It is most likely the fan switch, all the low speed work through a resistance, the full speed does not, there is only one fuse for the fan so if it works on high its ok and you say the fan works on high so the fan itself is ok
Apr 17, 2010 | 2005 Ford Taurus
Fan works ok blows cool air thermastat is ok
This could be that the actuator that opens the door in the heater is dead.. or the actual heater-core is bad. Which is costly and expensive.
Oct 19, 2009 | 2003 Mitsubishi Galant
SATURN 1992 SL1 FAN DOES NOT WORK.
test fan by unhoohing plug, run power and ground wires from battery to fan if fan runs then fan is ok, if not then bad fan, check fan relay and coolant temp sensor, if fan is ok,
Oct 02, 2009 | 1996 Saturn SL
Cooling fan not working
sensor may be bad. . any other symptoms that you think caused the cooling fan to fail?
May 27, 2009 | 1996 Nissan Maxima
FIRST ALWAYS CHECK YOUR FUSES AND RELAYS IF OK CHECK YOUR WIRING TO THE FAN IF OK CHECK TO MAKE SURE YOU HAVE ELECTRICITY TO THE FAN IF OK COULD BE THE FAN MOTOR OR THERMAL SHUT OFF BUILT INTO THE FAN. IF ALL THIS CHECKS OUT OK I WOULD SUSPECT THE COMPUTER!
Aug 09, 2008 | Chevrolet Lumina Cars & Trucks
Sony VAIO VGN-CR320ER Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
