Question about Jabra BT2080 Bluetooth Headset
How do I pair the jabra BT2080 to my blackberry torch? It doest find it or find it listening either
SOURCE: Jabra 250 Codes
Jabra 250 pairing code is nothing but 0000, however it has to be paired from an external device like a phone or computer.
I mean to say the pairing has to be intiated from the other device not the jabra 250.
hope that helps
Posted on Apr 08, 2008
homedesigner
  • 583 Answers
SOURCE: I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Posted on Feb 07, 2010
Obertelli
  • 3006 Answers
SOURCE: Cannot figure out how to pair my jabra with my
Go into your Blackberry's Bluetooth menu and after turning Bluetooth on, scroll down to Bluetooth Options and select the item. A new menu will appear, scroll to the item which allows you to set Bluetooth to be discoverable (by default, it's hidden). You may have to click on Options to find this menu. You can set it to be permanently discoverable (a security risk) or to be discoverable for just 2 minutes.
Turn on your Jabra headset by holding down the main button until the blue light stays on constantly.
Go back to your Blackberry Bluetooth menu and click "search devices". After your Jabra shows in the results list, select it to add it to your phone.
If prompted for a passcode enter either 0000 or 1111 (varies by Jabra model and by the country it's sold in).
Your Jabra should now be paired and the constant blue light will revert to an intemittently flashing blue.
If this has resolved your problem then please let me know by taking a moment to rate my answer. If not, then please add a comment and I shall attempt to assist you further when I'm next online.
Posted on Jul 22, 2010
casouzaj
  • 1118 Answers
SOURCE: My jabra bt2070 bluetoot headset blinks 3 times
Have you already tried to put your headset in pairing mode first? Anyway, to do it, starting with it turned off, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros);
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
Posted on Jul 28, 2010
Manish32
  • 70 Answers
SOURCE: I'm trying to pair my jabra bt2080 with my ps3 and
This bt2080 is not work with ps3 because your ps3 bt is ftp profile and it ask for pass key and we can't enter passkey in bt2080
Posted on Nov 06, 2010
Ipad2 can find Jabra BT2080
I'm assuming you meant "Ipad2 cant find"
Some Bluetooth device cant be detected by The ipad as it states here in a review of the product
"We tested the iPad with several Bluetooth mono headsets, and while we were able to pair some of them with the iPad 2, we were unable to direct any of the iPad 2's audio to the headset, nor were we able to use the headset's microphone with applications that accept microphone input."
Aug 31, 2011 | Jabra BT2080 Bluetooth Headset
How do i connect my headset jabra bt2080 to my laptop hp 620?
I also have laptop hp 620 and the jabra bt2080 which are working through a driverless bluetooth usb dongle v2.0 (China) after installing jabra pc suite_2.5.6. It is under my experiment as at the moment only the mic is working when you start windows speech recognition program. i am trying to get it working as playback device to listen music instead of headphone through jack.
Jul 16, 2011 | Jabra BT2080 Bluetooth Headset
My Blackberry is asking for the numeric pass key #
Most Bluetooth headsets require a passcode to sync with the phone and to make sure that is the device you want to sync with. Each of these manufactueres usually have a default passcode to use. It is usually in the manual.
For your Jabra BT2080 Bluetooth model the default code is: 0000 (4-zeroes)
Here is the link to your manual: http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf
May 12, 2011 | Jabra BT2080 Bluetooth Headset
Trying to pair my iphone with my jabra BT2080. It was paired before, but now I follow instructions and it just keeps searching, screen shows the Jabra not paired then below says Now Discoverable??
Make sure the iphone is still set to discoverable mode and try again. Turn off bluetooth and turn it back on if the problem persists.
Mar 06, 2011 | Cell Phones
Cannot get my phone to recognize the device. need steps 1,2,3
Here is the link pages 4and5 (http://img9.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf)
Feb 12, 2011 | Jabra BT2080 Bluetooth Headset
Dont have the pin code to link it with phone.
Hello,here is the code to pair the jabra BT2080 bluetooth headset with the phone,when it ask for the pin code,kindly type 0000 and you are good to go.
take care.
Dec 05, 2010 | Jabra BT2080 Bluetooth Headset
Jabra 2050 wont pair with blackberry storm
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Sep 05, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra BT2080 Bluetooth Headset Logo
494 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
