Question about Motorola Cell Phones
How do i turn off the verizon power up and down phone sound,phone is a moto V3m
  • RobNH Aug 27, 2008
    Just cant figure out how to turn off "power up/down" sound on the v3m. Seems like there's a menu option for other similar Motorola phones, am I missing something?
Dude, you up a creek. Me no find either
Posted on Oct 29, 2008
My phone is a Verizon Moto G , it sometimes freezes the apps, and then it turns off by itself. When I try turning it on it wont work, then i hold the power button and it vibrates, and take a while to
Panesha
Try running the phone in safe mode. To do this. Press power button then when power down appears. Long press power down option. It will ask if you want to boot into safe mode. Select ok the it will reboot in safe mode. Use the phone in safe mode for 24 he's to see how it works. If it works better, then there is a third party app you installed on the phone that I'd causing freezing.
Mark
Motorola Support
Nov 13, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Moto g wont turn on
Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
Sep 20, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
I recently purchased a Motorola Razr V3m prepay usage phone. It is supposed to have mp3 capability but it seems the only way I can load them is to purchase them through Verizon. A friend of mine says...
in bitpim go to edit->settings and make sure v3m is selected and click browse beside com port. select the port that says moto usb modem and click ok. if you use the phone wizard and select this then hit detect it may fail. dont worry about that. then click ok and on the view menu make sure view filesystem is selected. on the left click filesystem, then click the plus beside the folder and it will read the filesystem. find your music folders and you should be good. I know verizon locks down their ui so you may wanna look through modmymoto.com for guides and different software or hacktherazr.com. They both have a lot on the v3m.
Jun 22, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m: keyboard lights up:keys frozen,no power to screen.
If you did not replace the firmware,or try and hack the phone then it just died. Nothing last forever. This just means that the light did not die, but the hardware that holds the firmware could have went bad.
You could contact moto and see if they will fix it cheaper than you
can get one off e-bay. You only have 8mo left till your contract runs out. Do not use the upgrade through the carrier,or you are getting robbed. Either wait till it runs out and start a new one or go to
www.wirefly.com, you can get the same exact contract through the same carrier but get a way lower price on the phone,unless the phone you want is free. You could have someone try and reflash
a new firmware on the phone, but I don't think that is the problem.
Hope moto does something for you.
Mar 22, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Can't synchronize my motorola v3m with the PC
The only way to sync is if you have the sd card in,and you can only sync the sd card, if you did not have verizon,you could use motorola phone tools and sync everything, but verizon turned off transfer
in your phone because there thieves, but if you learn how to hack a razor you can use moto phone tools.
Dec 30, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Hey
you having a Verizon Phone, take it back, they should be able to show you step by step fix. or have it exchange.
Paulo
May 28, 2008 | Motorola Mobility RAZR V3
I cant use blutooth to transfer files to other mobiles
My friend, Verizon is the worst company that makes bluetooth useless, The reason why this is? is because Verizon has its V cast music going, so they disable verizon phones to be able to transfer music or pictures phone to phone via blue tooth, this sucks i know, i dont think u can even put music using motorola phone tools as verizon phones has a totally different interface,
Dec 05, 2007 | Motorola Mobility RAZR V3m Cellular Phone
My moto v3m from verizon says "bootloader usb init" and wont boot
Yes there is a fix... You need to reflash your phones.. to the person holding down the red button dont.. just press it .. but you want to press the other to down before the red button it will work! If you want to learn more about Flashing your phones goggle Mark Venture's name you will learn how to flash your phone properly! Unless it is under warranty then you need to take it to Verizon and tell them to reflash you phone...also under Bootloader to get your pics you should beable to run P2K Commander.. run it and get your files off.
Nov 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Razr V3M Power-up/Black Screen
I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
Oct 16, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Test Mode problem with Moto Rzr V3M
to get out of test mofe do this hit clr and the top left button right by the screen and then hit #073887 and turn it off
Aug 17, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
114 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
