Question about Precor EFX 546i Elliptical Version 4
How do you change the battery on a precor elliptical
  • Precor Master
  • 914 Answers
Using your model and serial number, use this link to view a service manual with procedure instructions.
http://www.sportsmith.net/
Posted on May 15, 2014
4 Suggested Answers
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
ZJLimited
  • 17970 Answers
SOURCE: How do I replace the
Check this reference guide in video: Precor+elliptical+trainer+change+belt
Hope helps.
Posted on Dec 28, 2010
I want to replace the battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Replacing battery
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
CHARGE BATTERY ON PRECORE EFX546I
The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Oct 14, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
1,043 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
