I purchased an RCA Wireless Stereo Headphone set from Canadian Tire in Whitehorse, YT 350 miles from where I liveSalesman told me it would work for any TV etc. Oop's I do not have a TV ( 5 ) in total as well as DVD and VCR's that this RCA Jack will fit into. Contacted the Source today by phone 350 miles away to purchase a connector cable......I should have waited and purchased from The Source as they are better trained for selling the customer the correct product. One would think from the enclosed brochure that the link required would have and should have been supplied ?
  • 10,515 Answers
Kindly mention the model number so that i could help you in a much better way.
Thanks!!
Posted on Sep 15, 2010
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Where is postal code Y1A 3M2
Building # Delivery Mode Street Name Suite City Prov. Postal Code 1-47
odd TESLIN RD WHITEHORSE YT Y1A 3M2
Jun 23, 2014 | Computers & Internet
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Can you send sound from a headphone output to an rac input? kvncloete@gmail.com
I assume that instead of a headphone you want to pop the sound through your stereo or something to that effect? You can take a cable with the same plug as your headphone and RCA sockets on the other end and plug it in and it should work
Aug 30, 2013 | SMS Audio SYNC by 50 Wireless Headphones...
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I have purchased a 50inch plasma tv which does not have a headphone socket. I wish to use headphones with this tv - can I use the composite audio red and white jacks on the back to plug into a headphone...
Hello smiths47 34:
What you will need is a Stereo RCA to stereo 1/8" cable that will connect you to your TV. You can get it at any radio shack or electronics parts store.
You might also like this which is a wireless headphone setup for your TV or phone system.
"CLICK HERE"
If the link doesn't work then copy and past this:
http://www.radioshack.com/product/index.jsp?productId=11300844#tabsetBasic
If this helps then click the thumbs up.
Sincerely, Peter N.
Mar 22, 2011 | LG 37LC2D Television
What is it for and how does it work
HI ....
Motorola Bluetooth Stereo Gateway DC800 is used as
Motorola Bluetooth Home Stereo Transceiver
By streaming music to your the Bluetooth Stereo Headphones, the Bluetooth Home Stereo Adapter turns audio devices such as home
stereos and MP3 players into wireless music systems. Just plug the
DC800 into your home stereo or MP3 player with an included RCA
cable or 3.5mm cable and you are ready to go. You can even hook
up to your RCA capable TV!
Thanks .....
With regards
Priya
Sep 26, 2010 | Motorola Mobility Bluetooth Stereo Gateway...
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Monitor Sound for JVC GZ-HD7
I've never heard of an adapter and after a quick google search and all the options voided the warranty, but if i were to make an educated guess... the easiest way and unfortunately bulky way of doing this would be to use the av jack and the cable that came with the camcorder, take one or both of the RCA stereo ends and pass them through a mic - line level converter and that should work, or you can use one of the stereo RCA ends and use a rca to phono adapter and then connect a headphone volume amplifier to that. Other than those choses, I see no other way to monitor your record volume with headphones.
JVC has been approached about this and they said they didn't include a headphone jack to reduce cost, but seriously. how expensive could that have been?
Oct 26, 2008 | JVC Everio GZ-HD7 Camcorder
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
