Question about HP LaserJet 4000 Printer
My hp laserjet 4000 will not print. Says it's currently offline. I'll hit pause and resume and it just goes back to currently offline. It's done it before, but this time it is just staying that way. Not sure how to make it work again. I am on a Mac system 10.5 X
SOURCE: pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Posted on Jul 24, 2007
bravsman
  • 94 Answers
SOURCE: "printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
Posted on May 25, 2009
  • 89 Answers
SOURCE: Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Posted on Jul 17, 2009
  • 89 Answers
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Posted on Jul 18, 2009
  • 30 Answers
SOURCE: HP LaserJet 4000 that stays off line.
REINSTALL PRINTER DRIVER AFTER DELETING THE DRIVER SOFTWARE (NOT JUST ICON) SORTS MOST INKJET ISSUES
Posted on Oct 05, 2009
Hp laserjet 4000 printer always saying "off line" and not printing what could be the problem
Please Clarify, does it say offline on the printer itself or on your printer driver. If it says offline on the printer itself, normally pressing the go button should put it online. However, at the age of that printer the buttons could be dirty/worn out, I have had control panels fail quite often as of late. If it is saying offline on the computer driver then that is a whole different set of issues and I would need to know what operating system you are running.
Jul 20, 2014 | HP LaserJet 4000 Printer
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
The HP laserjet 1012 printer has the online print status: "paused". I click resume and it goes back to pause. How do I troubleshoot this? The printer is on a shared network.
load the drivers in another system locally..check..if problem solved un install the divers reconnect & check..
If problem presists replace formatter..
Sep 06, 2011 | HP LaserJet 1012 Printer
HP laserJet printer 4100 is locked in idle or offline won't print
hi
· Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Jul 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
My HP 4100TN laserjet printer keeps going offline, in the middle of my printing. i switch it on and off and then it will resume. can you help please
first try a cold reset... power off machine hold down green button when power back on..if problem persists..replace with internal jetdirect card..
620n
Dec 29, 2009 | HP LaserJet 4100tn Printer
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Was printing fine but now when I send something to print, the printer doesn't respond at all and just shows the "ready" screen
Is it connected directly to your PC, or is it networked?
In your printer dialog box, does the printer say "ready"? it may be "Paused" or "offline". Right click and select "resume Printing", and/or "use printer online"
Are you sure the cable is still connected and working?
try removing and reinstalling driver.
Mar 11, 2009 | HP LaserJet 3600n Printer
HP LaserJet 4000 Printer Logo
307 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
