Question about Mitsubishi ColorView XL30U Multimedia Projector
The picture on my projectors (i have 2 with the same issue) seems to be slightly disfigured, in that rather than being squared off on the screen it looks more like a trapezoid of sorts. Is there an easy fix for this?
  • 54 Answers
There should be an adjustment in the menu for "keystone". That should do what you want.
Posted on Sep 15, 2010
Picture is not square on screen right side considerably higer than left _ can't get it squared
Have you tried the keystone correction. You must have the projector squared/lineup to the area you are projecting.
Jun 17, 2010 | InFocus Office Equipment & Supplies
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Nov 17, 2009 | NEC NP60 Projector
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Picture not square
keystone should help in your opinion. adjust the keystone and the picture should be a square then.
Oct 28, 2008 | Hitachi CP-X275 Multimedia Projector
INFOCUS Screenplay LCD projector...
Hi there
I take it the Projector is ceiling mounted ?
If this is the case check that it is installed with the lens of the Projector in the facing straight to the middle of the screen or try adjusting the bracket's swivel head to move it a bit - should do the trick !
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi ColorView XL30U Multimedia Projector Logo
79 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
