Question about Toshiba Computers & Internet
Toshiba portege A200.I cannot get the CPU to run faster than 600 Mhz.I have done everything.
  • Michael Tracey
    Michael Tracey May 17, 2008
    Cpu info keeps tellimg me the cpu speed is 598 mhz. If i try to run dragon naturally speaking i am told my processor speed is not adequate. My toshiba L30 ( also with a celeron 1.6 ) shows up as a 1.6 and runs Dragon with no trouble. But I cannot get this portege to run faster than 600. systems info tells me there is a 1.6 g cpu but the speed is always 600, even after i put it on max perormance, run speed step etc,etc, It is driving me mad.
Found the solution. the bios needs a patch. once done the cpu speed is back to normal
Posted on Oct 31, 2008
    Scholar:
  • 183 Answers
Dear Customer,
1st thing is that how you know that this speed is maximum,& for knidly infor you that other softwares always prompt you to saw batter performance as they said but not possible,
try to compare with your FSB speed its similar to your speed you mesured,
THNX
Posted on May 16, 2008
Lock cpu5 -
you need to see an expert to replace your pc cpu. its highly delicate and if you have never replaced one its dangerous and you can destroy your computer completely
Oct 04, 2013 | Toshiba Portege R205-S2062 (PPR20U01S02X)...
My processor is rated at 3000 but is only running
What you are trying to do is called overclocking, and there are some excellent guides for that on the internet, like here: http://www.compunamics.com/overclocking.htm
I suggest you read this before proceeding the overclocking.
You can open the BIOS (press a key like F1, F2, F8 or del during startup). Somewhere there will be a menu with options for voltages and frequencies (units in V and MHz)
As you have read, processor speed depends on the multiplier and front side bus speed: CPU Multiplier x FSB = CPU frequency.
Right now, your frequency is 2200 MHz (presumably 11 x 200)
To get it to 3000 MHz (3GHz), you either have to raise the option called FSB in the BIOS to 270 (270 x 11 = 2970), or increase the multiplier to 15 (200 x 15 = 3000). Before you do so, write both the values down, so that you can reset to them, in case things go wrong.
I sugest first trying to raise the multiplier from 11 to 15. It may however, be locked at 11. If you can get it to 15, you're done, your CPU is now running at 3 GHz.
If not, you'll have to go through some more trouble.
First, you'll need to find your memory (or RAM, or DDR) multiplier and frequency, in the same menu as the FSB and CPU multiplier. Write them down as well.
As you have also read, increasing the FSB will make your CPU and memory go faster. This may however, be too much for the RAM to handle.
With the FSB frequency and multiplier, you can calculate the frequency of your RAM just as with the processor.
You will now have to change FSB from 200 to 270, so you'll also have to calculate a new RAM multiplier, if you want the RAM to run at the same speed.
For example, your RAM frequency can be 200 (FSB) x 2 (multiplier) = 400. If you then increase FSB to 270, your RAM will run at 300 x 2 = 600. You will have to lower the multiplier to get as close to 400 as you can get, and preferably lower, if 400 cannot be achieved.
Having done this, you can slowly start to increase FSB, I would suggest by 10 at a time. As soon as the PC has trouble starting, in the BIOS, increase the CPU voltage by one step, until it runs stable again. However, as your CPU is rated at 3GHz, you shouldn't have any trouble with this,and should not have to increase voltages.
If you encounter any probems, let me know!
Dec 15, 2009 | ASUS A7N8X-E Deluxe nForce2 Motherboard
Reset password
you will need a dongle that plugs into your parralel port that will allow you to reset the bios password
you can find diagrams on the net of how to create a dongle for the password reset and the plugs are available from any good electronics supplies store
Regards AL "Alstech"
May 25, 2009 | Toshiba Portege 7200CT - PIII 600 MHz...
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Aug 20, 2008 | Intel SuperMicro SUPER Motherboard - 810...
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Aug 18, 2008 | Toshiba Satellite A205-S4617 Notebook
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Nov 04, 2006 | Gateway Pentium III , 600 MHz (1515824)...
Computers & Internet Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
