Question about Maytag Dishwashers
Clean light will not come on. only two years old
  • Jennifer Turner
    Jennifer Turner Sep 15, 2010
    What is the model number of the unit?
  • 901 Answers
If the washing is good, do not bother. The problem could be due to bulb not working or may be a circuit problem.
Posted on Sep 15, 2010
Is the scanner light failing?
You're probably right.
If it's four years old, would a replacement be more or less than you'd expect to pay for the repair?
Mar 08, 2015 | Epson Stylus DX8400 All-In-One InkJet...
What do the red light with abell shape which is lit up mean on my 18 year old tricity bendix freezer mean
It's a temperature warning that the freezer is no longer at the correct temperature. Check all is clean and working, door seal intact etc. If short of gas, probably time to get a new one!!! Bet it won't last 18 years this time though!
May 01, 2014 | Freezers
Clean button will not go off
Alternate solution: Within 6 seconds, alternately press "heated dry" then "normal" buttons. Wait for all lights to come on and for the diswasher to finish washing the load.
Jun 19, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
Light spots on interior upholstery
Some vinyl if not cured properly will chemically change and cause spots or even runs. Make sure the spots are in the fabric and will not come clean. No chemicals to clean. If new, one year old, should be under warranty
Oct 16, 2009 | 2009 Ford Fusion
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
Car wont start
First clean all battery terminals ensure there is no corrotion, after cleaning them light coat with a dab of grease to protect from further corrosion.
Although the lights may work, the battery may not have enough power to kick the starter over.
Since you specified no noise, suggest you check the starter solenoid first. Ensure the battery is good and holding the charge.
5 years old, time for a new one. 3 years old, need to have it check for CCA (Cold Cranking Amps)
Ensure your alternator is working properly. May not be charging the battery.
Nov 14, 2008 | 1998 Ford Mustang
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
