Question about Janome MyLock 644D
What are the spool holder caps and nets for? - Janome MyLock 644D
  • 161 Answers
I have never used nets on my overlocker. I have used them to stop the thread from coming off when not on the machine. Are the spool holders like a tee ****? If so they are to hold the cone shaped thread spools.If they are like a disc, you can put them over the cotton to stop it being pulled off the stand, although i never used them on an overlocker
Posted on Sep 15, 2010
Replacing spool holder
If you search online for:
Make + Model + "replacement parts"
you may find a replacement. Otherwise, you can usually manufacture a spool holder using a drinking straw, wooden skewer, or something similar. There are also standalone spool holders for sale at various web sites. The spool holder doesn't necessarily have to be attached to your machine but can set behind or to the side of it. Some sewists throw the thread spool in a big coffee cup and just let it bounce around in there.
Jul 29, 2016 | Sewing Machines
When the needle is not pulling the bottom tread
is this the first time you use a sewing machine? if you are very familiar with the way the thread is pulled out of the bottom spool, I'd say you need a technician, here is how to install bottom spool in case you don't know. after filling spool, pull thread out through the small gap on the side of the spool holder, then holding the small arm on the holder outward insert the spool holder in to the socket and release after fully inserted. after that the thread should come out the top by manually turning the machine to lower needle
Dec 24, 2014 | Sewing Machines
Where can I get the piece that holds the thread on the spool? It is a "must have"!
I think you mean the thread spindle ? Or spool holder ? Does yours have a cap that prevents the spool from popping off ? Or is it just the spindle that's missing ? Either way, you may be able to get a replacement from the manufacturer, or try Ebay, where there are all kinds of machine parts for sale.
Helps if you include the make and model of the machine you are asking about in questions like this.
Oct 08, 2014 | Sewing Machines
How does the thread holder work
It sounds like you are asking how to use the spool cap. These are put on after the spool of thread to hold the spool in place.
Oct 05, 2014 | Husqvarna Huskystar 215 Sewing Machine
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
Lost spool cap/holder
my CG550 is running very slow I need help?
Jul 09, 2010 | Singer CG550 Mechanical Sewing Machine
Upper thread breaks ''inside''. Then thread pulls tightly. Must be re-threaded to sew.
Check the spool to make sure there isn't a nick in the cap where the thread can catch. If there is it can be smoothed with an emery board, or just turn the spool so the the thread feeds from the opposite end of the spool.
If the thread is unwinding too fast and pooling around the spool pin, you can use a thread net to help stop this.
Thread nets come in a long tube and you cut them to size. They can be found with machine embroidery supplies or at a dealer.
Feb 19, 2010 | Janome Sewing Machines
Viking Designer SE missing the spool holder where can I buy one?
some authorized husqvarna viking dealers have websites where you can order the spool holder. Might just call an authorized dealer and purchase over the phone. Other 3rd party vendors are http://www.pd60.net and http://www.sewingpartsonline.com may have these. Hope this helps.
Mar 14, 2009 | Husqvarna Viking 1
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Janome MyLock 644D Logo
114 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
