Question about Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4010
Can you charge the unit by usb port
I have bought a charger for my Maestro 4010 in the magellan's web and it's with mini-usb port... and don't charge anything!!! Incredible!!!
Posted on Jun 05, 2008
This unit can not be charged from the USB
Posted on May 17, 2008
    Scholar:
  • 183 Answers
Yes ,
but design some external cicuit for voltage control system as pda needs,
but ,irts possible,
THNX
Posted on May 16, 2008
Maestro 4010 screen freezes up when first button pressed. Switch off and restarted but does the same each time.. Where do I get the software to update ?
there is no updates for the magellan 4010 at this time. if you havent tried the reset (little pinhole on the left side) i suggest you try that 1st.
power on your 4010 and after it boots up, use a paper clip to depress the reset switch and let it reboot. that may or may not fix it, because you could have a bad digitizer (the touch part of the lcd)
let me know how you make out.
bill
Dec 15, 2009 | Magellan Maestro 4040 GPS Receiver
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan Maestro 4000 GPS
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3225 usb charging
Go to system setting and you will see the charging icon animation and displaying battery strength.
May 24, 2009 | Magellan Maestro 3225 Car GPS Receiver
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Problems with Magellan Maestro? 4040 GPS power connection
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
I have a Magellan Maestro 4040 That will no longer pingower on.
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 12, 2008 | Magellan Maestro 4040 GPS Receiver
How to recharge mastero fron computer useing ubs port
You can try charging the unit with the supplied uSb cable but the output on the USB is so low that it might only partially charge the battery or it will take eons to charge
Feb 11, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4040 GPS Receiver Logo
330 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
