Question about Performance Teknique ICBM-775 Car Audio Amplifier
The diagnostic LED indicator comes on and i dont know why
  • 30 Answers
First check the ground as it is the most important par to the wiring and operation of an amp. itshould be t the frame of the careand touching clean bare metal no paint! if that doesnt work it may be going into termal protection meaning ts getting too hot. you should always be able to continously keep yourhand on the amp, if its too hot try backing the gains down a little. next make sure the spakers are ired to a safe impedance for the amp. if its wired too low it might could put the amp into protect mode or blow it! most amps are only 2 ohm stable nd 4 ohm stable when you bridge them...hope this helps!
Posted on Sep 15, 2010
I have a 2003 uk zx636 b1h and I want to fit a gear indicator. From the photo could you say if this is the diagnostic port and do you know what is plugged in as it is tapped in the loom.
ahh its a bike
no doesn.t look like a diagnostic port
must have just a neutral light then
cant find a free repair manual for that
to add the gears indicator needs a bit of kit and
a wiring diagram ,a led test light or volt meter 26232498-0s53sopfgfmmsl1emt5qzwqf-4-0.jpg
Jul 06, 2016 | Cars & Trucks
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Sony Televison & Video
Dell dimension 2350 won't boot, the psu fan comes on and the fan for the heatsink, the hard drive makes so noise what so ever and the disk drives won't open at all.
Depending on the Power and Diagnostic LED indications the system appears to be in a no post state. If the power LED is flashing Amber, the power supply is suspect. Solid Amber, indicates a motherboard problem. The Diagnostic LEDs on the back marked ABCD can give more specific POST error details.
Mar 05, 2010 | Dell Dimension 2350 PC Desktop
HOW WILL I KNOW IF BATTERY IS BAD OR THE CHARGER
ON UR CHARGER U WILL FIND: Diagnostics with LED indicator are 5 indicators to communicate battery charge status: charged, charging, power line problem, replace pack, and battery too hot or too cold.
Jan 16, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
WHAT IS A ORGENGE LIGHT ON MOTHER BOARD MEAN
The orange light indicates that system has power. Other than that, the LED on the motherboard has no other function.
The power LED on the front of the chassis and the diagnostic LED on the back do have diagnostic functions.
Jan 04, 2010 | Dell OptiPlex GX270 PC Desktop
I dont know how to pull the codes on a 1993 volvo
Volvo Code Retrieval Accessing Trouble Codes 89-93 models (and later non-turbo/non-OBDII models)
Fuel Codes Locate the diagnostic unit behind left strut tower and remove its cover.(see image) Connect selector cable to socket #2,which tests the fuel codes. Turn the ignition switch to the ON position(engine not running). Enter the diagnostic mode by pressing the push button on the diagnostic unit for at least 1 second, but not more than 3 seconds. The red LED light will start to flash,count the number of flashes in 3 flash intervals. The flashes will be seperated by 3 second intervals.Make note of all codes. If no codes are stored,the LED will flash 1-1-1,which means the fuel system is operating correctly.
Ignition Codes To access the ignition codes,follow the above procedure,but with the selector cable connected to the #6 socket on the diagnostic unit.
NOTE:Turbocharged models may have seperate codes for the turbo system and are accessse by hooking the selector cable to the #5 socket.
Rate this.
Dec 28, 2009 | 1994 Volvo 940
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
BMW 318i Service Light
BMW SERVICE RESET Take a small wire, paperclip, or elect wire and bend like a horseshoe. No light or equipment necessary Open the diagnostic data port, the one were the little pacman centre is located. Turn the ignition to position 2, don?t start. Connect pin7 always first and then pin 19. Hold for 4 seconds. Remove wire and settings will be reset. Warning if you hold the wire longer than 10 seconds you may reset inspection intervals 1 and 2. I?ve done this twice and it definitely work on my E36
Jul 19, 2008 | 1996 BMW 318
Performance Teknique ICBM-775 Car Audio Amplifier Logo
87 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
