Question about KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator
Why is my Kitchen aid model number KSRX22F. lower air vent freezing?
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
The rubber door gaskets tend to crease often times causing the cold air to escape. If your door gaskets are OK it's time to call the repair man!
Posted on Apr 08, 2009
  • 145 Answers
SOURCE: I need a coupling for
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
I have a kitchen aid KSC24C8EYY the problem is that the refrigerator does not cool stay cool below 40 degrees, Holding 43-45 range. The freezer maintains freezing but not to the 2 degree setting.
well, how full is your fridge. if your fridge is blocking any of the return air vents, thats usually where the problem lies with side by sides. you need good air flow in these models for proper temps in the fresh food compartment
Dec 18, 2016 | Refrigerators
Kitchen Air. How do I replace the clutch?
Kitchen Aid do you mean?? What model, tip it over and find the model number on the base.
Jul 18, 2015 | Blenders
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid Unit - maybe 4-5 years old but past warranty. Freezer not freezing. Not that cold in fridge. I played with the dials 1. Are higher or lower numbers on the knob coldest? 2. What else should I...
Set dial to higher number in the fresh food compartment (large door) set the freezer
knob on the vent stack in the center or to the left (if it is set to colder, this prevents cold
air from getting into the lower fresh food compartment). Colder means the freezer
gets colder.
Also if you have a failed defrost termination thermostat it will cause this
symptom on many models. (a lot of folks will disagree but I have only seen a couple
of defrost timers fail in 10 years). The water makes its way into the defrost termination
thermostat and corrodes the contacts inside. It is behind the freezer panel and has two
wires going to it. It is clipped onto a tube. You will need the model and serial from inside
the fresh food door (on the side panel) to get a new one, usually less than 20 dollars.
Remember to set the fresh food compartment temp from 34 to 39 degrees with a
thermometer in a cup of water for 24 hours. Don't forget to unplug unit if service is
required on the thermostat. Hope this helps.
Jun 08, 2011 | KitchenAid Refrigerators
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Over the Range Kitchen-Aide Microwave/Vent Stainless Steel
You'll need to provide the specific model number in order to get the part you need but here is a link to a company that should be able to get you what you need.. http://www.pcappliancerepair.com/whirlpool-parts.shtml
Hope this helps..
Sep 14, 2008 | KitchenAid Microwave Ovens
Drying problem
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
Feb 23, 2008 | LG LDF6810ST Stainless Steel Built-in...
KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator Logo
136 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
