Question about Canon ES190 Camcorder
After having been used only very little, the Eject stopped working. When you push the Eject button, the camera opens part way then stops. There is no way to insert or remove a tape.
    Problem Solver:
  • 17 Answers
You might have a broken belt. The camera needs to be opened by an expert.
Posted on Sep 15, 2010
CD DRIVE DOOR BUTTON JAMMED ON AX5900
You should see a small 'pin hole' on the face of the CD drive, usually near the eject button itself, but not always. Straighten a paper clip (med size is best) and insert into the hole. You will feel a little resistance (this is good) continue pushing the paper clip straight in until the door pops open. Almost all CD/DVD drives have this "manual open" pin hole for just such cases. Alternately you can open My Computer, point to the CD/DVD icon, right click and choose the "eject" option, this will open the tray if the physical button has stopped working.
Jul 15, 2014 | Acer Computers & Internet
Dvd, no eject disc
It sounds like your DVD is not getting any power to it. When you press the eject button does it show a power light for a second and then not move ? Also it is possible that some other DVD could have been in it and now it is blocking the door to open, look carefully at the door there should be a very small round hole on it you can use a paper clip straightened out to make a probe and insert it in the little hole and push you will have to push firmly and it should open the drawer. I hope this helps
May 02, 2017 | Televison & Video
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
DVD door keeps opening
sometimes they need to be pushed that little bit further in and make sure the eject button or open button is not stuck in .
hope this helps.
Apr 28, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Disk (CD) will not eject automatically nor play a CD. It make noise, (a clicking),trying to eject. In my computer, it will not show that the CD is in the drive.
Turn the power off before you try this. There's a small hole in front of most CD drives. You can straighten out a paper clip and try pushing it into the hole. It should go in about 1/4 to 1/2 inch and then stop. Press just a little harder and it may push open the tray and eject the CD. If there's not a CD in it, it may move it enough that it will reset itself. Once the tray is open, and the CD removed, you can power on your system. It should pull the CD tray back in. Once your system boots, try the eject button to see if it works.
Dec 02, 2008 | Everex Computers & Internet
Cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
Door opens "Slightly"
I had the same problem, and TomInMB
told me how to fix it:
What I did was to first remove the battery and AC power to "reset" the camera. I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VOILA!
I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism. Good luck!
Walt D in LV
http://www.thecinemaniacs.com/
Jan 10, 2008 | Canon ZR65E Mini DV Digital Camcorder
Cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Canon ES190 Camcorder Logo
106 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
