Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
Find the mode of the following numbers ; 21,25,27,29,29
  • 122 Answers
Mode is the most frequently occurring value. in this case 29
Posted on Sep 15, 2010
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
Richo infotec 3090 SC 593
- Toner Suction Motor Replace Alert.
- The total operation time of the motor exceeded 600 hours.
- The toner suction motor has reached the end of its service life.
- You can try rest it, after some time it will start to print light prints.
- So you will need to replace it.
- You can clear the code in Service Mode.
- To enter into Service Mode you need to follow the next procedure:
- Press the following key in the following order:
1. Press Clear Modes [yellow key] .
2. Press 1 - 0 - 7 [ with the blue keypad numbers ] .
3. Press and hold down Clear key [ C key] for 5 seconds.
(after release of the C key, the Touch Screen will change)
- On the touch screen press the [Cop SP] .
- Press the following number with the blue keypad:
[ 2 - 9 - 7 - 3 - 0 - 0 - 1 ] then press [ # ] .
- On the right side of the touch screen should write the following:
[ Toner Suction Motor Operation Time ] .
- Press [ 0 ] with the blue number keys, then press [ # ] .
- After doing all of this re cycle the machine by turning it off,
wait for 10 second, and then turn in on with the main power switch
[Red Power Switch] .
----------------------------------------------------------------------------------------*note: the machine will work again with this procedure but maybe,
after some time, or maybe even immediately after this,
the machine will start to make light prints.
Mar 12, 2014 | Ricoh Aficio MP 1600SPF Black Toner...
How do i find cubed roots on my casio fxii5es calculator? Step by step directions?
If you're in the LineIO mode, press 3 SHIFT [xth-root] then enter the number then press ) followed by =.
If you're in the MathIO mode, press SHIFT [xth-root] 3 then right-arrow, then enter the number then =
The xth-root function is on the x^ key, third row from the top, third column from the right.
To switch to LineIO mode, press SHIFT MODE 2. To switch to MathIO mode, press SHIFT MODE 1.
Dec 05, 2010 | Casio FX83ES Scientific Calculator
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
I can't get the calculator out of the exponent mode. ex. It gives me 7 -03 rather than .007.
You must change the number display to FIX. Press [MODE][7:] followed by a number betwee 0 and 7. This will set the number of decimal digits. Be warned that the Indicator FIX will be displayed on the screen.
This information is for the FX250D, but I trust it is also valid for the FX-250HC. If it is not, just look in your manual. If you cannot find yours, do not blame me, I cannot get hold of a manual for this calculator.
You can always take the time to play with the [MODE] key followed by [.] or a number. When you press the mode + number, look on the screen to see what indicator appears (deg, Fix, Rad) The one that makes FIX appaear is the one that gets you out of the exponential scientific mode.
Good luck
Nov 13, 2009 | Casio FX-250HC Calculator
Can you number pages with a Savin C3030 without actually copying the documents
Hello sir; Yes, there have SP mode it does the job,the procedure as follow; press "clear mode" + "107" thenpress and hold down for 3 seconds, then touch screen on copier SP, enter number 5212-003, 004 to open the program. press "exit" twice to end the service mode.
Sep 18, 2009 | Office Equipment & Supplies
How do i display decimals on casio fx 115es
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
Aug 12, 2009 | Casio FX-115ES Scientific Calculator
I need to change to mode to degress
Under the screen you can see atable of values at the right of which is written MODE followed by a small arrow.
If you want to set the degree as angle unit, you press the MODE key followed by 4 (as seen in the table I was referring to).
Similarly, if you want to set RAD as the angle unit you press MODE then 5; and MODE then 6 for GRAD.
However if you just want to convert a number displayed on the screen in RADs or GRADs into DEGs , you press SHIFT then MODE then 4. your number should be converted from the unit it was expressed in into degrees.
Same thing if you want to convert into RADs: SHIFT then MODE then 5.
Hope it helps.
Aug 02, 2009 | Casio FX-115ES Scientific Calculator
I need to retrive the key operator code for a Aficio 1060/1075. How do I do this?
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one .
Follow the instructions and will be easy.
1. enter the service mode.
2. To enter the service mode press one after other the follow keys on the control panel of the copier.
press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad.
on the screen will appear "execute" press the touch button and than by pressing
"exit" several times you will exit from the service mode.
NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM"
After clearing the key operator code you may enter new one.
If you need something else please ask
PLEASE RATE ME
Jul 15, 2009 | Office Equipment & Supplies
Computers & Internet Logo
42 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
