Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
  • Philips Master
  • 8,457 Answers
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Posted on Sep 15, 2010
Why is my TV picture dim
Hello David
It sounds that the back light inverter board, and back light CCFL lamps to your TV need to be checked. It will be best to contact any service technician, because to check its back light CCFL lamps, you must disassemble the display panel, a very skilled work indeed. If you are sound in electronics, you can check it. If you wish to know more http://electronicshelponline.blogspot.com/ check this link. It has details. Pull up older posts there by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Sanyo Dp55441 TV
Picture went blank. Still have sound. What is wrong?
When was the last time,this tv the projection lamp was replaced?The projection lamp in the tv now,has not been replaced the last 1 1/2 or 2 years.The tv been on and watches 4 or 5 hours a day.The projection lamp life span is over.Require a new projection lamp.
Aug 11, 2010 | Philips 55PW9363 55" Rear Projection...
Tv lamp light stays on.
The projection lamp inside on this tv,about 1 1/2 or 2 years,tv on and watches about 4 or 5 hours a day?The projection lamp life are over.Tv require a new projection lamp.
Jul 05, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Pictures very dark, Brightness all the way up. Contrast does not adjust
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
May 28, 2009 | Hitachi 46F500 46" Rear Projection...
Sound but no picture
you've lost your backlight, the inverter board are part of the panel, so hopefully u just los a couple caps on your power supply. You should check your powersupply for lifted caps.
Mar 21, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Dec 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
NO PICTURE
sounds like the vertical output is causing the CRTs to shutdown for protection. Try resoldering the vertical output IC that will often correct the problem. If not the vertical output IC may be defective.
May 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Not Supported Mode
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Apr 02, 2008 | Samsung HLN5065W 50" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
