Question about Refrigerators
Magic chef refrigerator mcbr360wf manual - Refrigerators
bobotfel
  • 236 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
Some technicians tried that, they just replace the compressor oil. But I did try that yet.
Posted on Jan 02, 2008
  • 7 Answers
SOURCE: Refrigerator stopped working
check if the in side light works and if it does then it is your thermostat.allso check the power supply to your frige
Posted on Apr 19, 2009
  • 2418 Answers
SOURCE: why does my magic chef refrigerator leak water on
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Posted on Jun 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Where is the defrost timer on a magic chef
The defrost timer for your model is located in the fresh food compartment. Providing the model number above your post is correct. The part number for your defrost timer is 61005388
You can visit my sites if you like and enter part or model number to get the models or parts you need. If you need help or need answers let me know.
Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Jul 09, 2009
  • 146 Answers
SOURCE: Can I leave my magic chef refrigerator outside in
If I understand you correctly you want to store your refrigerator outside in the frozen weather - no I do not recommend doing so at all - you may however store it in your basement or elsewhere but not outside in the freezing weather :)
If on the other hand you meant running and using your refrigerator outside in the wintertime, NO ! I see people give misleading information on yahoo answers - refrigerator compressors are designed to work inside a given temperature range - if it is too cold - your compressor will run very short cycles and not properly remove the extra moisture/humidity. Usually you should not run a refrigerator if it's colder than 60F.
If you mean storing your refrigerator outside, not plugged it and not working but only to conserve your food - again NO - I would not recommend it either - there is too much variations in temperatures in the winter time - sometimes you get mild weather other times cold, and besides, with some refrigerators the extra insulation does a good job at sealing the cold air inside or the warm air if the fridge is not working - I don't think you will be able to maintain both freezer and refrigerator to SAFE and optimal temperatures, don't take the chance. Besides, the last thing you want is for your sealed system to freeze over, including compressor, coolant, coils, etc....... so my answer is no - don't do it.
Posted on Aug 28, 2009
Magic chef refrigerator will not defrost and ice maker will not work
verify that the doors are closing properly. If they are not you will have to manually defrost it to get it running right again. I doors are ok, think about finding a control board
Dec 03, 2016 | Magic Chef Refrigerators
What is the Cu Ft. of my Magic Chef Refrigerator
Hello there.
First you need to find your refrrigerator Model number.and put that in your question friend.
Go here and see for yourself how many Magic Chef models there are friend.
http://www.ebay.com/sch/i.html?_odkw=magic+chef&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR4.TRC1.A0.H0.Xmagic+chef+refrigerator&_nkw=magic+chef+refrigerator&_sacat=0
Sep 21, 2014 | Magic Chef Refrigerators
How to unlock majic chef wine refrigerator
Magic Chef should be able to help with this problem
Feb 26, 2013 | Magic Chef MCWC30MCG Compact Wine Cooler
Who manufactures Magic Chef refrigerators
google "magic chef" trademarks you may be supprised.(haier IS THE WORLDS LARGEST MANUFACTURER OF WHITE GOODS IN THE WORLD......MADE IN .......CHINA....)
tata make the worlds cheapest NEW car 1500 dollars
pre tax......made in india.
Jul 04, 2010 | Magic Chef CTB1821AR Top Freezer...
Just bought magic chef ctf2124ar fridge. cannot
Not a bad refrigerator I work on them for a living they have put out decent products in the past. Magic chef was made by maytag in they past probably a wpl made product now. Its probably got a calrod defrost heater and an embraco compressor two good things to have. Stick with it.
Jan 22, 2010 | Magic Chef CTF2126AR Top Freezer...
Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
