Question about Kenmore 63942 Dryer
Dryer quits rotating after it runs for a while.I just replaced the belt same result.
  • Kenmore Master
  • 43,501 Answers
Hi, The motor is getting hot and kicking the overload off... you will need to replace the motor...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Oscillator is not rotating
make this test and fix it. God bless you
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt , and often the idler pulley, because the pulley tends to wear out at the same time. . If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Check our videos on testing a motor and capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity. When Door is open no continuity when closed you should have a reading. If it's defective, you need to replace it.
Jul 30, 2013 | Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
WHY DOESN'T MY DRYER TUMBLE
Hi, If your dryer doesn't tumble,The problem might be from three different reasons,which are described below,check these:
1.BELT; Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
2.MOTOR; If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt.Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
3.DOOR SWITCH; Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks and good luck
Jun 21, 2010 | Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
I have a kenmore 80 series electric dryer. It gets
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Dryer quit getting hot
I would suggest that your thermostats/cut-outs have gone as a result of overheating .. Also replace the door switch as this is a safety device to stop the drum from rotating whilst the door is open
Aug 25, 2009 | Kenmore Dryers
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Kenmore electric dryer
Belt
Motor
Door switch
  • Remove the belt.
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
  • Remove the belt.
Jun 15, 2008 | Magic Chef Dryers
Kenmore 63942 Dryer Logo
35 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
