Question about Hunter 52" Ceiling Fan With Light And Remote Control
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or off light, fan speeds work fine in all speeds.
    Problem Solver:
  • 6 Answers
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Posted on Jan 24, 2011
  • 2 more comments
  • Joe Paxton Jan 27, 2011
    Dont be intimidated by the idea of completely disassembling the remote, it only has 3 screws, no springs or small parts to lose, and is an amazingly simple task. You can do it. Now go fix it, you will be glad you did.
  • pacioli Mar 18, 2011
    Amazingly simple and worked great! It's just like new! Thank you, joepaxton!
  • Bk_1364 May 31, 2011
    Thanks for the suggestion. Worked like a charm
  • Joe Paxton Sep 08, 2015
    Also have a site that I found with replacement units. I ordered 4 for my house.https://www.hunterceilingfanstore.com Goto the parts tab, then the remotes tab and choose the one that matches your needs. Good luck!
Yeah, you're exactly right, Joe. The rubber inside turned to black goo. I wiped that off and now the remote works again.
Posted on Nov 17, 2011
Hood has a remote blower (VTR1400Q). Only working on MED and HIGH setting.
See if it has a blower motor resistor(controls speeds) and replace it.
Look up model at repairclinic.com & see it the resistor is a listed part. See link, go to repair help by model number. Forget it. I just checked the only part they sell is the motor for $267. You can buy a new hood for that.
May 16, 2016 | Thermador PH48ZS Kitchen Hood
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
Dacor RV46 Inoperative
Tom - Did you ever solve this? i have the same thing going on?
thanks
Bill
Mar 18, 2009 | WindCrest Pinnacle WPN36 Kitchen Hood
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Jan 15, 2009 | Heating & Cooling
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
1,631 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
