Question about Goodman CKL60AR60 Air Conditioner
I got a goodman heat pump and in a/c mode the fixed orfice sounds like it is gurrgling could this be fixed with a txv
  • Jason Pendleton
    Jason Pendleton Sep 15, 2010
    WHAT ARE YOUR PRESSURES/LINE TEMP/AIR TEMP SUPPLY AND RETURN IS THE INDOOR UNIT UP HIGHER THAN THE OUT DOOR UNIT HOW IS THE FILTER HOWEVER I WAS TOLD LAST WEEK THEY HAVE A SCREEN FILTER IN THEM IN THE OUTDOOR UNIT BUT DONT KNOW THAT TO BE TRUE
  • Goodman Master
  • 43,501 Answers
No,
The problem more likely is that the unit is not charged correctly...or there is air in the system...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 15, 2010
3 ton heat pump with piston in air handler. After unit shuts down it makes loud fluid flow noise for about 2 minutes
adding a tvx will not help. the sound you here is the pressure equalizing and that has got to happen for the compressor to start again the next time. A tvx will give you a higher efficiency because it can adjust to changing temperature conditions. Only way i know to quiet the noise is to try to insulate the lines better.
Sep 14, 2014 | Goodman GSH130301 Heat Pump, 3 Ton, 13...
Ineed info on changing a expansion valve ona split a/c unit
If indoor coil TXV then start by pumping system down-while system is running in the cool mode close discharge line valve at outdoor unit (the small line) watch low pressure side of gauges as needle falls start closing the other valve idealy u want valve completely closed around the same time the PSI reaches "0" and kill power at disconnect by unit at the same time. Now your refrigerant is in the outdoor unit. However if TXV was completely closed off you may have refrigerant between the TXV and outdoor unit in the little line in which case that would have to be recovered into a cylinder. Now you can remove old TXV also remove filter drier if is one and install new one just before TXV either way this is to catch any trash or moisture left in system. Next pull a vacuum on the system perferably down to 500 microns if not pull for 45min close gauges and let sit 10min or so and see that needle doesnt rise if it does u have a leak find leak and repair start process over. Its best if u have nitrogen or CO2 to put some pressure on lines before pulling vacuum upto about 100PSI and bubble soap joints see that pressure doesnt drop then release pressure and start vacuum once vacuum complete open valves on outdoor unit.(do not remove hoses from lines until valves opened or u loose vacuum and have to start over) reconnect power and check charge by subcooling method add or remove refrigerant if needed. ADD:if u have to braze TXV in then wrap it with a wet rag so it doesnt get to hot and damaged.
Aug 27, 2012 | Goodman Heating & Cooling
I installed a r-22 3 ton unit and i have negitave pressure on low side which was does the orfice go into the a coil
You have a blockage in the lineset somewhere...was a pipe plug left in??? or was one stuffed inside the copper and was not noticed?? The orifice or TXV maybe plugged or bad...
Bottom line is that you will have to cut the lines apart and track down the source of the blockage by using co2 or nitrogen...
heatman101
Aug 06, 2011 | Goodman CKL60AR60 Air Conditioner
High suction press (98psi), normal head press (140psi); full sight glass;low super heat (10 degrees);normal subcooling (13 degrees) new txv, new evaporator, new condensing unit 70 degree air from vents ...
lower fan speed.....and double check head pressure, sounds very low!!! should be around 250-275.....also make sure the return air grill is large enough.
Aug 09, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
3ton heat pump googman 14 seer
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Nov 11, 2008 | Goodman GMS90703BXA Heater
My goodman heat pump has frozen up 3-4 times already this summer. It is a dual system 10 seer (i believe are the terms). Every time someone comes out they can't figure it out because the system is...
After system has been running 10-15 minutes, the discharge air temp should be 18-22 degrees colder than the air being sucked in. If the air is more than 22 degrees colder then the problem is with air flow. Check filters, blower speed, make sure all vents are open, is indoor coil clean. If the discharge temperature is less than 18 colder, then the problem is with the refrigerant portion of the system (low charge, improper flow control of freon into coil) the key is if you have an orfice or a TXV (Thermal Expansion Valve) to control the flow of refrigerant into the coil. TXV's are known to fail with intermittant problems, however, most 10 seer systems do not use a TXV, they use and orfice which could have debris in it affecting the flow of freon. Hope this helps. When you rate my solution, please keep in mind that I am a technician that normally diagnoses equipment by checking it out in person. I do the best that I can with the information that you provide me on Fix-Ya.
Thank You,
Chillmaster
Jul 07, 2008 | Heating & Cooling
Goodman 3 1/2 ton unit
I work for a very large reputable goodman dealer. Your equipment appears to be a correct match. The correct orfice should have been taped to the outside of the outdoor unit in a baggie right beside where the pipes connect. Things will run alot smoother though if you scrap the orfice and have a TXV installed (thermal expansion valve) . This is a mechanical device that adjusts the flow of freon into the indoor coil based on the immediate needs of the coil. After that, balancing the refrigerant is a piece of cake as all we need is about 10 degrees of subcooling to make sure we have plenty of liquid to the TXV.
Jun 08, 2008 | Heating & Cooling
3.5 TON GSH14 GOODMAN WITH TXV
is it a heat pump? or the furnace cutting out?
Jun 03, 2008 | Goodman GMS90703BXA Heater
Goodman CKL60AR60 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
