Question about Sony BRAVIA KDL-V40XBR1 Television
Where can I find a table top stand/base for a Sony Bravia KDL-V40XBR1 LCD TV? It is currently wall mounted and I need to remove it from the wall and use a table top stand, however, I no long have the original base that came with the TV. Or, is this TV compatible with TV stands of other models. I have found a stand for sale for a KDL-37M4000, but don't if that will work. Thanks!
techman
  • 3130 Answers
SOURCE: Stand By/Timer Flashing 4 Times
It means that there is a horizontal sweep or High voltage circuit falure. It is a high voltage circuit and only a trained tech should attempt to repair these sets. A TV set is not a place to be experimenting inside of.
Posted on Sep 26, 2006
eagle338
  • 4889 Answers
SOURCE: sony tv
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram.If you can then let me know..
Posted on Oct 19, 2007
skippy101
  • 143 Answers
SOURCE: 1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Posted on Nov 03, 2007
mistersony
  • 320 Answers
SOURCE: model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Posted on Oct 26, 2008
  • 115 Answers
SOURCE: Sony Wega Model #KP51WS520
Press in order on the SONY remote "display - 5 - vol. down - power" .that will show diagnostics indicating 9 Zero Cross Detect . You shoud take it to a servicer.
Posted on Oct 19, 2009
Testimonial: "Thank you very much.. "
Install table top stand
If you wish to get more details about this, check the site linked here. It has disassemble instructions with illustration. You can understand the procedure you wish to know. Pull up older posts.
Nov 25, 2013 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
How do i remove the table top stand from my sony bravio model KDL-52V4100
Need replacement screws for my sony 52v4100..I lost the screws for the table top
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
How do you uninstall the stand on a Sony model KDL-V40XBR1. I need to get the stand off and there is no manual or instruction sheet.
You ca nget the manual on the link below on how to install the wall mount. Just click on wall mount manual and on page 2 will telll you how to remove the stand.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDLV40XBR1
May 23, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
CN'T GET THE TV OFF STAND KDL-V40XBR1
Here's the link to your tv's OWNER'S MANUAL and HOW-TO GUIDES:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDLV40XBR1
And here's the direct link to the Wall Mount Instructions:
http://www.docs.sony.com/release/KDLV26_32_40XBR1wallmount_bracket.pdf
Good luck and please comment back if this was helpful or if you need further assistance.
Jan 29, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
The plastic stand that is attached to the TV bottom, how do I remove it so I can mount the TV on the wall?
Click Sony Support link to download instruction manual about how to remove stand from KDL-V40XBR1 tv.
Hope this will help you.
Thanks.
Jan 28, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony bravia pedestal stand is unstable
http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf This link will show what it looks like when removing base to wall mount.They always recomend a mounting strap that connects to the rear of the TV and then screws into the table it will be sitting on.Not sure what they expect you to do if you have a glass top table. http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf
This is a link to all the downloadable manuals and what not.Well hope this will help,and good luck.
Mar 13, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
Feb 07, 2010 | Sony KDL-32S3000 32 in. LCD Television
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Nov 26, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Wall mounted sony 40" tv how do you take the stand off the bottom?
It is held in with screws. Unscrew the screws and it should slide right out.
Apr 06, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony BRAVIA KDL-V40XBR1 Television Logo
366 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
