When i turn on my computer it says no signal - Computers & Internet
  • 490 Answers
That is the monitor saying it has no connection to the computer, check the cord at bo th ends for the monitor, and then check the video adapter in the control panel portion of Windows if that is your operating system. Sometimes the video card actually comes loose, although this is rare.
Farmerbear at FixYa.com
Posted on Sep 15, 2010
Turn signal relay 2007 Avalanche ltz
There is no turn signal relay or flasher , Computer controlled by the BCM - body control module .
Turn Signal/Hazard Lamps
When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
This is something best left to a qualified repair shop that has a professional type scan tool . Could need new BCM , which would need programming . Scan tool would be able to check switch inputs for BCM .
May 22, 2016 | 2007 Chevrolet Avalanche LTZ
My blaupunkt tv said no signal then when i turned it off it stayed off? What can I do
my tv says no signal - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../my-tv-says-no-signal/td.../13296...
Jun 28, 2012 - My tv says no signal. ... Start here. Sign in or Sign up ... Plug in the TVfirst, then the cable box, turn on the TV, then turn on the cable box.
Computer turns on, monitor says "no signal" [Solved] - CCM
ccm.net > Forum > Windows
Mar 10, 2013 - I recently had problems of it randomly turning off at any time, i could be working ... Then i decided to take out the wireless B PCI card, then the computer booted! ... tycoonXD) and i needed to start my computer up again cause it didn'tworkwell, ... i've tried many things, turned of the powerbutton waited for 39 ...Missing: blaupunkt
Jan 05, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
The monitor turns on but says "no signal"
Usually this means either your cable isn't connecting properly to your computer or there is a compatibility problem between the monitor and the computer. Are you getting the "no signal" message AFTER you have connected the machine to a working/ turned on computer? Because the monitor will ALWAYS say "No signal" if it isn't hooked up to anything. Also, you will want to verify that none of your pins (from the end of the cable) is missing, and that your cable is firmly seated into the port on your computer. Other than those things, you really need to say a lot more than just, "The monitor turns on but says 'no signal'" for anyone to be able to assist you.
Feb 17, 2014 | ViewSonic VA721 17" LCD Monitor
What makes the cooling fans turn on?
there is a temperature sensor that feeds the ecm(computer)a signal to let it know if the motor requires cooling operation at a predermined temp,which the ecm sends a signal to the cooling fan relay to turn on the cooling fans.when the temp lowers to a predetermined temp the signal is turned off to the ecm and the ecm turns off the signal to the fan relay to turn off the cooling fans.
Sep 18, 2011 | 2000 Pontiac Grand Am GT
The adapter wont connect to my wifi it see my connection but wont connect, im working on linksys wireless and all my laptops work
The router is required in situations where a connected computer requires to share signals with another computer that has no signals. The router would turn on to recognise a computer that has wiifii only lacking the transmission of signal to another computer. Routers are required in situations where the owner has more that one computer. Consult with an internet services provider to attain signals to the computer. Once achieved, acquire another compute that requires sharing the signals. Once the router is turned on in this situation, wiifii on the computers are detected on the router that captures to distribute the details of networking.
Feb 04, 2011 | Computers & Internet
When i turn it on it says no signal? Does this
The no signal can either be "no signal" or a signal that is out of range. Check first by connecting the monitor to a known good video output (ie another computer). If that works, then the problem is with the source and not the monitor. Sometimes the source computer has its resolution set too high and the monitor will not be able to process that resolution. The no signal message will occur then as well.
Dan
Sep 28, 2010 | BenQ FP91G+ 19" LCD Monitor
No signal or loses signal from computer
Keep the computer on when you plug it it
so have the computer ready
May 12, 2009 | Acer PD725P DLP Projector
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Monitor signal is off
no power from the computer, replace the power supply in the computer.
Aug 06, 2008 | Gateway GT5408 PC Desktop
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
