Question about Microwave Ovens
I have an Old Sears general Electic gas range and oven. It is used often and on for hours a day. Lately there has been less of a gas flow not allowing the oven to regulate proper temp. Is there a way to possibly recalibrate the oven?
  • 96 Answers
You should try cleaning the orifice first. Actually before you do that, if you can see the flames on the oven this simple check will determine a cleaning. Turn oven on and look at the flame, if you have propane it should be light blue at the base a little darker blue in the middle and have a little orange tip. If you have natural gas it should be almost all blue with maybe a slight tint of yellow in the center of the flame. If the flame looks like it is almost all orange. It needs to be cleaned. I can assist with the cleaning also, but confirm with this test first. Please rate answer accordingly!! Thank you
Posted on Sep 15, 2010
Do you know what the average electric cooktop lifespan is? We have a Kenmore that is 9 years old and working fine. However, we are in the midst of a renovation and are wondering if it wouldn't be wise to...
The life span of the range depends on it's use or abuse.... Common issues are burners and the connections that the burner plugs into. These are not hard to change out.... There is nothing that can make the stove useless, if you keep after it. Newer units do a better job of retaining the heat within the unit, oven wise....Which is nice.
A gas range is certainly nicer, so they say. It is faster, but has one odd issue: if you boil water over, you can put out the flame and have raw gas running in. Most work this way, expensive units have thermal sensors that would turn off the gas flow in flame out condition....
My wife loves her gas range....
Mar 08, 2011 | Microwave Ovens
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Jun 09, 2009 | Whirlpool Microwave Ovens
I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
Dec 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
isabelmvaldes@gmail.com
Nov 16, 2008 | Kenmore 63792 Microwave Oven
Whirlpool microwave/oven model RM286PXV3
Just so I understand, you replaced the fuse inside the oven? If so, I would suspect a bad thermostat attached to the magnetron. This device interrupts power when the unit gets too hot. I've included a representative photo. After so many years your magnetron may be bad, too. Once you get the oven working, if it cooks and doesn't trip the thermostat again, it may be okay. PLUS - It looks like this model has manual rotary controls. If so, it's common for those to develop bad contacts after so many years. I would consider that my third suspect. Those controls are called the thermostat (not to be confused with other part by that name that I discussed above) and the selector switch. One could easily be bad. You can check part prices at Sears online at http://www3.sears.com (the "3" is supposed to be there) Some other things that can cause a "dead" condition: - bad connections on the small circuit board where the fuse is mounted (if such a board is present) - bad connections in the wiring Good luck.
Nov 04, 2006 | Whirlpool MH1140XM Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
