Question about Kenmore 23513 Progressive Bagged Canister Vacuum
Need a new carpet beater head as the old one is burned out...where to buy? 116.52650300c
  • 54 Answers
I would suggest checking the Sears website. They have a very nice interactive parts search system. Several different models meet on the website come up with the model number you provided.
Here are a few leads:
http://www.searspartsdirect.com/partsdirect/part-model/23513?searchedModel=23513&postFilter=true&modelFilter=true&brandId=0582&productCategoryId=&brandFilter=true&categoryFilter=false
Posted on Sep 15, 2010
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
It smells like it's burning when I vacum/what's wrong with it
Tammy May:
Unplug the machine and remove the foot plate (at the bottom of the vacuum head) and check the belt that drives the beater brush/bar. if the beater bar is hard to turn, pull the beater bar and belt out, check the inside circumference of the belt to see if the motor shaft has worn it down in one spot. If so, remove the two bearings (one at each end of the beater bar) and remove the hair, carpet fibers, strings and any other junk from the bearings and the ends of the beater bar. lubricate the bearings with oil (thin machine oil like 3 in 1 oil works best. roll the bearings with your hands until they spin freely. Now would be a good time to check the bottom of the foot plate where the dirt is vacuumed up. check the hole in the middle of the foot plate and check the hose for clogs if the hole and foot plate hole are clear, reassemble the bearings on the beater bar and install the beater bar (with a new belt) and reinstall the foot plate. The machine should run well for you.
Jan 19, 2013 | Eureka Vacuums
My Dyson - DC14 won't push on my new plush carpet, front end
Same issue: new plush carpet, 7 year old tried and true DC14, wouldn't push across regardless of beater brush on or off. Called Dyson this morning, they suggested removing the small gasket between the floor plate and the assembly holding the beater brush. It's about a 12' gasket just under the screws used to remove the floor plate. Pushing is still a bit stiff, but it is a definite improvement. Whew!
Jul 29, 2012 | Vacuums
Burning rubber smell when vacuum running
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Most times that burning rubber smell is the result of a worn out rubber drive belt. This belt is used to drive the rotating beater brush in the head of your vacuum. When the belt gets old and loose, the drive pulley starts to spin in place and heats up the belt instead of turning it properly.
To fix this issue, just unplug your vacuum, then disassemble the bottom head in order to access the beater brush drive belt. Remove the old belt, then replace with a new one, and then reassemble it. The old belt will probably have a part number on it so you know which type to buy, or you can just look up your vacuum model number online to find the correct replacement part for it.
Since you did not provide your vacuum's exact model number, here is a link to a short video which demonstrates the basic belt replacement procedure for a generic vacuum cleaner:
http://www.youtube.com/watch?v=T11KkkFspos
To view the video instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 28, 2011 | Kenmore Vacuums
The beater bar of the power head of my canister vacuum Electrolux 2100 turned off.while vacuuming,however the suction was in tact and the hose appears clear.
If you take the carpet head apart and take a look at the belt that drives the beater bar -- if it is stretched or broken, replacing it should resolve the issue. If the belt is in good shape, check the beater bar for debris that could keep it from spinning (I have long hair and it tents to jam up the carpet head of my vacuum on a regular basis).
If neither of the above solutions help, you might have an issue with a dead motor, or no power to the carpet head. Check that all of your connections are nice and tight and give it another shot. If it is still not working, I recommend bringing it to a repair shop to see if it would be cheaper to fix the part or buy a new one.
Jun 01, 2011 | Vacuums
Beater head makes loud noise on 'carpet' mode
Possibly a belt problem, but more than likely a brushroll problem.
The bearings are cheap and nasty, and are prone to siezing.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 29, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I HAVE A KIRBY AND IT KEEPS BREAKING AND BURNING BELTS.
Hello, Check this guide to be sure that your brushroll is in correctly. Follow it step-by-step and it should help of your brushroll spins freely. If it doesn't, there are new brushrolls available through the links in the guide as well.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 06, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Dark marks on carpet after using hoover
these dark marks are burn marks from the beater bar itself. most walmart, kmart, and target shelf vacuums from hoover, dyson, and any cheeper vacuum has a hard bristle system. I've noticed even on the high end hoovers as well that they do the same thing. the best way to save your carpets is to see if there is a replacement beater bar that can be substituted for your vacuum. i dont know what style of beater bar that particular one is but check with your local vacuum repair center to see if they have something with softer brushes you can use insted otherwise i would recommend a new vacuum with softer bristles. usually something that is half as stiff as what is already on yur unit. you culd also try lifting the hight setting as a temporary solution.
Sep 06, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Beater bar belt too loose
You need a new belt, they stretch after awhile and will slip.
Apr 07, 2008 | Vacuums
Kenmore 23513 Progressive Bagged Canister Vacuum Logo
61 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
