Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My Kenmore side by side doesn't freeze or cool. The fan motor still runs but the "freon motor" makes a buzzing noise when trying to run. Is there a fix or is it time to buy a new freezer. This unit was manufactured in 07/2001.
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 18, 2010
Model 77862791 not cooling, all obvious stuff checked, clean coils etc, door, fan motors, Inside temp about 50 Degrees, Ice not freezing, motor and fans run constantly.
Check to see if the tiny captube near the filter drier is kinked. This sometimes happens when somebody moves the unit or cleans it. If that is ok then you need to see if the low side freon pressure is 5PSI
http://www.youtube.com/watch?v=qlx48QxQVVM
Sep 19, 2013 | Kenmore Top Freezer Refrigerator
KENMORE MODEL 106.53532300 SIDE BY SIDE WILL NOT FREEZE OR COOL. FANS RUN, BUT A CLICKING NOISE INSTEAD OF COMPRESSOR RUNNING, COMPRESSOR IS VERY HOT. WHAT SHOULD WE DO?
its most likly the start run relay . this plugs onto the side of the compressor and changes it from start to run . these models seem to have this problem in this age range call sears you can get a relay put it on your self not terribly expensive
Jul 04, 2011 | Refrigerators
Mccall FS10-E freezer has been sitting unplugged for two years and now won't cool (I believe it worked before but not 100% sure). When plugged in, there is a constant buzzing from the fan motor. ...
Here are a few thoughts.
Possible a very small freon leak. A low level of freon will cause a "No Cooling" situation.
There is a small possibility that since it sat for so long, that the rings on the compressor may not be sealing properly and the compressor is now "Weak" and does not have the capacity it needs to do the job.
Buzzing from what fan motor? Evap or condenser? If the motor buzzes but runs in the correct direction (rotation) and at the correct RPM. I would not be too concerned about the noise at this time.
I'd start with these items before going any farther.
Let me know if I can be of any further help.
Dec 03, 2010 | Freezers
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrigerator: Freezer not freezing
a blocked condenser can cause a warm up situation,and after youve done this you have to wait 24 hours before making desision on out come.but other possiables are condenser fan motor slow,its fan blade dirty.defrost problem,frost on back frezer panel can be a sign of issue.evap fan moving air slow[inside fan]run time,is it running enough[thermostat controls that]if all those ok could be restriction in sealed system,that where the freon curcit.if moisture,or particles they can get caught in the cap tube[small tube to create persure so then freon expans to a gas]that should give you a few ideas.God bless ,tom
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Dec 26, 2008 | Maytag MTB1891AR Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
