Question about Hotpoint Refrigerators
Hotpoint RLA64 fridge gets too cold. - Hotpoint Refrigerators
  • 8 Answers
SOURCE: fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Posted on Dec 15, 2008
SOURCE: Hotpoint RLA64 getting too cold.
The thermostat capillary on a Hotpoint RLA64 (and possibly RLA80) is inserted into a tube. The tube becomes detached from the cooling element and so does not sense that the fridge has reached the desired temperature. It then carries on cooling resulting in ice build-up and freezing of goods.
As you cannot remove the top or back of the fridge, you cannot fix the capillary tube back into position. What you can do however, AFTER ISOLATING THE FRIDGE FROM THE MAINS SUPPLY, is to drill a small hole adjacent to the thermostat capillary tube and another in the roof of the fridge next to the interior light and pass the thermostat capillary INTO the fridge cabinet. Use tape to attach the capillary across the roof of the fridge and down the centre of the rear wall curling the last 50mm or so back up towards the top of the fridge. As long as you have dried the wall of the fridge and stuck the capillary securely in place, your fridge should now work correctly when powered up.
Only tackle this job if you are confident and ALWAYS ISOLATE the mains supply.
Posted on Jul 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: freezer working but not fridge
most likely a defrosting problem in the form of a bad defrost timer or element in a unit that age. One way to prove it is a defrosting problem is to remove the contents of the freezer section un plug the unit and place a fan on it for about 2 hours. This will make a water mess so be prepaired for it. Then plug it back in and load it up with the frozen food you removed... If it works fine for a few days then you have a defrost problem. After the test run here .. if it is in good shape still I would have have it serviced.
Posted on Jan 16, 2010
heatman101
  • 43501 Answers
SOURCE: hotpoint fridge/freezer.Fridge not getting cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 28, 2010
rickead1
  • 1998 Answers
SOURCE: i have a hotpoint ffa90 fridge/freezer .fridge not
hello jennie,
remove the rear panel on the inside rear of the freezer to assure that you dont have an icebuild up on the evaporator if you do have an ice build up this is mainly due to your unit having a defrost issue this is mainly caused by one of four reasons. The defrost thermostat, the defrost heater, the defrost timer all of these three can be checked by doing a continuity test on some units a defrost timer is not used and instead the use of an electrical control board is instead used also assure when you remove this panel that the fan behind that back wall in the freezer is also running if not replace the fan if you have no ice and the fan is working you would then look at the either the damper door on the inside of the refrigerator or the damper control. The freezer side of a refrigerator is the only side that produces the cold a small door opens and closes allowing the cold air to go into the refrigerator side when the unit gets to cold the door shuts and likewise when it gets to warm the door opens if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
here is also a link on why this happens and what the pieces look like http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm
Posted on Apr 07, 2011
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
My hotpoint side by side hss25gfpaww is not cooling on the fridge side but the freezer seems ok. Fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Hotpoint HSS25GFP Side by Side...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Jul 03, 2009 | Refrigerators
Refrigerator Not Getting Cold--HotPoint HSS22IFMD WW
Take a look to the thermostat first!
Jun 24, 2009 | Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Further questions about one of your posted solutions
make sure that the thermostat id correctly wired in
May 29, 2017 | Refrigerators
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Refrigerators Logo
87 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
