Question about HP Officejet H470 InkJet Printer
Officejet HP470 refuses to print. The ON/Off light blink green, the continue light blinks orange and the cartridge lights are lit continually. When the printer is turned on you do here a noise like a motor runs briefly. Also, a message displays of the computer "The cartridge is installed". I did note that the print head can not be moved manually form the left position as there are (2) rubber rectangular shaped pads and a plastic piece located between the pads that project up far enough to interfere the print head from moving form its parked position. There are no error messages that are displayed. Followed the recommendations in the instructions to no avail. HELP!! This isn't a cheep printer.
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
SOURCE: printer won't print
  1. first you make a self test print by the printer, for this you first switch off the printer then press and hold the button on your printer, and switch on the printer
  2. if you get the test printout all the characters on paper
  3. now you can find the printer is ok and it is work in good condition
  4. now check the cable connection, if it okay
  5. check the installed printer driver software
  6. for these purpose
  7. re install the printer software
  • If your computer not self printing do as follows
  • now your printer is in trouble
  • clean nozzle, print head, align catridge
  • for these go to printers and faxes, on start menu, click right mouse button on the printer icon, select printing preferences, select maintenance option
wish you all the best
Posted on Jan 29, 2008
ctf1800
  • 4402 Answers
SOURCE: Blinking light, will not print
go here
Posted on Sep 03, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: hp 1160 light blinking
orange & green light on
Posted on Dec 23, 2008
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please call Lexmark Technical Support.
Apr 12, 2011 | Lexmark E260dn Laser Printer
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Hp 1160 light blinking
Nov 11, 2008 | HP LaserJet 1160 Printer
HP Officejet H470 InkJet Printer Logo
515 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
