Question about Dishwashers
DISHWASHER-GE GL613716A will not drain. re/re drain and removed restriction,food ect. it will not drain still. performed self diagnosis on front control panel as per trouble shooting information supplied with dishwasher when i bought it, all tests passed except when commanded on, the pump did not drain water from the dishwasher, i do not know if the pump came on as all test functions are perfomed at the same time for some reason, which made a bit of noise making it hard to even hear the pump. thanks.
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 15, 2010
Can you replace just the dryer on a frigidaire gallery heavyduty?
Good Afternoon friend, thank you for your post!
From what you have described your Frigidaire dishwasher is not draining. Before contacting a professional technician I would advise you to check the filter at the bottom of the dishwasher tub or your drain line to assure there is no restriction. The filter is located at the bottom of your tub under the spray arm. If that is dirty it could cause your dishwasher to not drain. Additionally if your drain line has a clog or restriction it will not allow water to pass through. If both components appear to be clear I would recommend having a professional technician out to perform a diagnosis. This will help to avoid any unnecessary part purchases. Hope this information is helpful. -Matt
Feb 16, 2015 | Frigidaire Dryers
GE GLD6700N dishwasher won't drain
remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
My portable GE dishwasher is clogged and wont drain
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Dishwasher won't drain
I rethought your problem and will provide a generic answer that is common to your brand of DW....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and good day...Thanks for rating my effort......thanks....The Fang.
Apr 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain
In order for you to see the diagrams..here is a great link...anyone can use....
http://www.applianceaid.com/gedishdrain.html..you may need to scroll down to get to where you need to be...but these issues are GE specific...and there are other related issues you can see here.
I have all this material in a vast data bank of my own but it is PDF format which does not translate well to these medium.
Good luck and good day...please rate my effort.....The Fang.
Hope this
Mar 28, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher will not drain it is a GE nautilus.
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Will not drain
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Brand new dishwasher overflows all over counter during each rinse
It sounds like you have an Air Gap...a separate device that is used to prevent back flow into the DW. Take off the top of the air gap and see if it is gunked up and or clean it with a shop vac...as well disconnect the line to the drain evac it as well... also there is a reservoir in the back that is attached to the drain pump...take the screws out...see that it is clean and free of debris...be careful as glass or other particles can be in there. Also have you had a new dispoal installed if so the drain plug may not have been removed. As i read more I am certain you have an air gap...make sure it is cleaned and free from obstruction....if this does not solve the problem...here are some other GE specifc things and a link to help......
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Here is some GE specific info and a link.....
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Mar 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
