Question about Electronics - Others
My acr2000 a/c stuck at initilization - Electronics - Others
  • 5,807 Answers
Thanks in advance for choosing Fixya for assistance.
While i prepare for possible solution to your problem
here are links where you can have additional info
for your system
[PDF] ACR2000 Hardware Manual
And post if it is not the one you are referring to.
Could you also please add more description or
give more details on the problem you are having.
Posted on Sep 16, 2010
Why cant use the phone?
See if this solution helps from Cisco's website:
https://supportforums.cisco.com/discussion/11385276/spa-303-stuck-initilizing-network
May 13, 2014 | Cisco 303 Ip Phone
I have a mitsubishi wd-60737 and all the inputs were deleted how do I get them back??
You have to reset and initilize the set. For more details, you have to download the service manual to this set. It has all options, which I can't include all here. It has a reset initilization guide, in tables,. No tables can be included by this window.
Jun 13, 2012 | Televison & Video
I get error when initilize sd 4GB. "card error"
Try connecting the SD card to your computer and formatting it that way.
If this does not work, then the SD card may have failed.
Check the contacts on the SD card to make sure there is no debris on them.
Dec 20, 2010 | Canon MV960 Mini DV Digital Camcorder
Acr 2000 ac machine will not leave initializing screen on start up
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Mar 12, 2010 | Measuring Tools & Sensors
Rca Opal 4208 Blank screen
If stuck on initilizing then firmware went bad.
You need to go to RCA website download the latest firmware.
After you download the firmware.
plug in mp3 player to your usb device of pc.
After its plugged in install the firmware.
While its installing windows should find the palyer.
Leave it plugged in for about 1 hour to give the battery time to charge a little.
Jan 14, 2009 | RCA OPAL M4001 MP3 Player
Stuck on "initilizing"
There are 3 things that will prevent it from going "ready"; they are
1. a paper jam (did you retrieve all of the page out of the printer?), all it take is a small piece of paper in the wrong spot and that will do it.
2. No paper in the paper tray.
3. The ink or toner cartridge is not seated properly or just plain missing. A color laserjet has 4 cartridges.
Good Luck!!!
Dec 02, 2008 | HP Color LaserJet 2600n Printer
HARDDRIVE FAILED
Get a new V3000 hard drive. They are cheap. That hard drive is corrupt.
Aug 14, 2008 | 3Com NBX® V3000 (3C10600BUS)
AKAI 54" rear projection TV
The convergence sensors either need to be re-initilized or one of them is bad. The service menus needs to be acsessed to re-initilize the sensors.
Apr 08, 2007 | Akai PT5492S 54" Rear Projection...
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Electronics - Others Logo
119 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
