Question about Toshiba Satellite A305D-S6835 Notebook
I have a Toshiba A350D-S6848 laptop...when i hit the power button all the lights come on fan running, dvd drive running, hdd running, nothing on monitor
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 15, 2010
Hi! I have a laptop repair Satellite A305D-s6848. I turn the laptop fan spins, no display, it can not turn off power button. Can there be a reason for the bios? Please help Hdd drive is removed,...
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 20, 2011 | Toshiba Satellite A305D-S6848 Notebook
I was working on my laptop (internet browsing), I let my room, came back 10 minutes later and my laptop was completely shut off. It will not turn back , no lights, no nothing. PLEASE HELP! Toshiba...
Unplug and take out the battery for a few.
Put battery back in, plug it back in and see if it will power back up.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Apr 09, 2010 | Toshiba Satellite A305D-S6848 Notebook
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Oct 29, 2009 | Toshiba Satellite A305D-S6848 Notebook
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Oct 06, 2009 | Toshiba Satellite A305D-S6848 Notebook
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
I have a Toshiba Satellite A70 laptop.
you can try the memory try one stick at a time. also try the laptop with as little components as possible.
remove the dvd drive, hard drive and wifi card and see if it will boot.
then put each one back in at a time and try it to find the culprit
Apr 24, 2009 | Toshiba Satellite A70-S249 Notebook
Toshiba Satellite A305D-S6835 Notebook Logo
282 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
