Question about Craftsman Garden
I have a Craftsman pressure sprayer Model # 580.752060 and it will not pressurize the spray. I have replaced the 6 plastic valves. Motor runs great. Suggestions?
    Problem Solver:
  • 16 Answers
Check the unloader valve for dirt or wear.
Posted on Sep 15, 2010
Testimonial: "need description of unloader valve"
  • gbarden355 Sep 15, 2010
    Which is the unloader valve? I removed the one with a strong spring, greased and "worked" it so that it moved freely. I adjusted the set screw in the end both ways and still no pressure.
Where is the reset button located?
The manual for your sprayer list several possible causes of the motor not starting, but does not indicate the presence of a reset switch. It has Thermal Overload but is reset by simply letting the motor cool.
From the manua: lProblem
A.
The unit will not run.
Troubleshooting cause
1.
The unit is not plugged in.
2.
Tripped breaker.
3.
The pressure is set too low (pressure
control knob set at minimum setting does
not supply power to unit).
4.
Faulty or loose wiring.
5.
Excessive motor temperature.
6.
ON/OFF switch is defective
Hope this helps!
Dec 05, 2015 | Titan Impact 1140 High Rider Airless Paint...
Leaking around Pressure Switch. Ordered & replaced switch but still leaking
Some pressure switches have a valve that reliefs the compressor head pressure when the motor stops and closes the head pressure relief valve when the motor runs.
There is a check valve that keeps air pressure from coming back to the compressor head and the relief valve.
I think the check valve is leaking tank pressure to the relief valve and compressor head.
The check valve is where the pressure switch mounts on to and it mounts threaded on to the compressor tank.
Try replacing the check valve
Nov 01, 2015 | Craftsman 33 gal Air Compressor 6 hp...
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman 5 HP MO-6436 Unit will run, pressurize, and hold pressure pretty good. But, after use has decreased pressure to the cut-off point where it should kick back on, it does not. Well, it turns...
If the unit does not unload properly the motor will have difficulty starting. Make sure that the intank check valve is not leaking air back out of tank (with pressure in tank, remove hose from compressor at tank checkvalve and spray soapy water). Replace as needed if leaking or try to repair. If the valve is not leaking then issue my be unloader valve at the pressure switch. Follow small airline from checkvalve to pressure switch. Small valve stem at the pressure switch should release air in line when pressure switch cuts off. Listen for small amount of air to be released when unit shuts off, if air continues to leak out, then check valve is leaking. Replace with generic parts making sure of fitting size. Good luck
Mar 08, 2011 | Craftsman Air Tools & Compressors
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
I have a Generac pressure washer, model #01450-0, with a Honda 5hp motor. The motor runs fine, but the pressure hose pulsates as if the pump is intermittently making pressure, and the pressure out of the...
Take a small diameter wire and poke thru the discharge hole of the spray head to clean out.
Second time in 6 months that I had the same problem. The problem is alway in the spray head.
Jul 23, 2009 | Garden
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
Garden Logo
407 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
