Question about Frigidaire FAC127S1A Air Conditioner
Check filter light is on. I pulled it out but dont know how to clean it.
  • 144 Answers
NOT SURE WHAT YOU HAVE BUT MOST PERMANENT FILTERS THEY SAY TO SOAK IN WARM SOAPY WATER FOR 10 MINUTES IN BATHTUB THEN RINSE WELL
Posted on Sep 15, 2010
  • Frigidaire Master
  • 43,501 Answers
Just take the filter to the kitchen sink or the bathtub or utility sink if you have one....turn the filter with the dirt down and then just run water through it to clean it off...
heatman101
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
Choke seems to be on... runs very rough....
There are several ways to do it
a. Check carburetor if not clean pump it on the intake if that not solve try to clean it. with Lacquer thinner to dissolve the dirt.
b. Check spark plug if some are not working. In checking try to pull one by one the high tension wire and listen if the sound vary if the sound remain when pulling one wire mean you have problem with your spark plug. So replace all spark plug with the same spec.
c. or lost compression on cylinder.
d Check if you fuel filter if some dirt and replace it.
e. Clean your air filter with compressor or replace it
f. Check the clearance to the Contact Point it must have 1 mm or .8 mm spacing when not at firing mode ( just like the thin of the hacksaw blade the space of the gap of the contact point.)
Aug 12, 2011 | 1984 Jeep CJ7
I have a 1992 toyota pickup 4x4 it misses real bad while im driving and the check engine light wont come on so therefor i can pickup any codes...while drivin it will cut in and out REALLY bad the rpms will...
check converter , maybe clogged , the fuel filter under the hood been changed? if light won't come on its fuel related, pump maybe going bad check pressure .
Mar 23, 2011 | 1992 Toyota Pickup
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
2003 chevy pu starts wont stay running stalls when i give it gas
maybe you need to have dianostics done on the inboard comp
Jun 03, 2009 | 2003 Chevrolet S-10
Low rpm on start up, check engine light came on.
If you dont have a code reader go to Autozone and have them read them for you. it sounds as if you may have a defective sensor. It may be a simple cheep solution to try to clean your mass air flow sensor. You Can do this by taking some brake parts spray cleaner to clean it up. the brake parts cleaner dosent leave any residue so it wont harm the sensor. If you dont know where the sensor is located it is usually located just after the air filter box.
May 28, 2009 | 2006 Ford Fusion
Not rinseing or spinning
Plug off the power and pull out the machine to get at the back. Remove the panel at the bottom where the discharge hose comes out. You should see a thick black tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in, just as you found things; check that it's well fixed by running a spin cycle before sealing up. Not familiar with your model, but the above shd help.
Mar 16, 2009 | Hotpoint Ultima WF860 Front Load Washer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
LG front load washer
Go to troubleshooting above, you might find a solution.......
Apr 13, 2007 | LG WM1812C Front Load Washer
Frigidaire FAC127S1A Air Conditioner Logo
154 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
