Question about E-Machines Computers & Internet
Computer hard drive does not startup Then after 4 or 5 using switch to turn on it might start but showing bars on screen or freezing on desktop ????? thank you
  • E-Machines Master
  • 27,725 Answers
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU
reple all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
good luck with this
Posted on Sep 15, 2010
When i boot into the operating system which is win7 machine freezes and shows up a blue screen.when i placed the hard disk into a usb external case and connected it to a pc a message box showed saying i...
Get a windows 7 install or repair disc. Make sure your pc boots from the disc drive. When you get to the installation screen tick REPAIR YOUR COMPUTER. Then select the installation you want to repair and choose STARTUP REPAIR.
Mar 13, 2011 | Fujitsu (MJA2320BH) 320 GB SATA 3 Hard...
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
My sons acer kav60 is stuck on the windows start up screen and will not reboot.
If it's still under warranty, take it into the shop for repairs.
Jan 14, 2011 | Acer Aspire One PC Notebook
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Mar 31, 2009 | Computers & Internet
Ongoing problem with HP dv9000 Pavillion
I have a pentium 4 computer but the computer does not work properly.
Jan 15, 2009 | Computers & Internet
Home pc
hello,
try this,
click on start then run, type msconfig in command box,
system configuration window should show up. click on tab called startup. click disable all, then apply, then click ok, it should ask if u want to restart. please restart the computer.
what will it do? it will disable all startup applications.
if this resolves the issue, then you would know its one of the startup application causing your computer to freeze it.
also right click on bottom bar, then click task manager.
click on tab called processor.
average processor is 25-30.
in my laptop i have only 19 processor runnning.
if you have alot of processor running that definitly cause PC to slow/freeze.
hope this information help you
Dec 22, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Computer Freezes During Startup (Urgent!)
Try firstly, on start up keep pressing F8 until a menu comes up. Look for the line that reads 'Start windows with last known good configuration', move cursor to it with the up or down keys as your mouse won't work; and press enter. Hopefully your pwill restart and run as normal. If not you may need your Windows cd.
Jan 03, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
21 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
