Question about Sony CDX-GT100 CD Player
Keep losing radio presets
I set up the radio srtations with the preset buttons, but I lose thwem when I take key out of dash.
  • stevemvs May 16, 2008
    Hi. Thanks. Yes its sorted. I was installing in on my (17 year old tomorrow) son's 1999 Corsa that we've bought him for his birthday and the original radio had been removed when we bought it. I swapped the yellow and red bullet connecters round in the wiring harness that was with the radio and hey presto. Incidentally, I have just finished checking eerything I think this CD/radio is superb. Thanks again.
    Brigadier General:
  • 6,966 Answers
Most current car head units requires two (2) kinds of B + supply; the yellow should be connected to an always on/constant B+12 such as the positive terminal of the battery. This is responsible for the memory and setting/configurations not to be erased when powered off. The red wire is connected to a switchable B+12 such as the ACC terminal of the IGN switch making the radio work only when the key is turned to ACC. Of course,the black is ocnnected to the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 16, 2008
  • Louie  Role
    Louie Role May 16, 2008
    Glad to be of assistance and appreciate the rating...
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
The GPS system on my Boss BV9370NV loses navigation from memory during a trip when the engine is shut off and restarted . The clock and programming for the radio and presets are ok, only the GPS system ...
If you are getting power from the cigarette lighter socket for the GPS unit you loose power when you switch the engine off. If that is the case find a power line that has power all the time and hook into it to give permanent power to the GPS
Mar 17, 2013 | Bv9370nv Double-din In-dash Navigation A/v...
I have a 1998 mitsubishi eclipse gst. had the battery chanced and now the radio won't work. have code for radio but don't know how to enter it into radio.don't know what buttons to push. owned car about 7...
The 1,2,3,4 preset buttons on your radio toggle up only through the digits 0-9. The 1 preset button is the first digit holder, and so on for the 4 digit code. If you go too far just keep pressing the button, and it will go back to 0, and you can get back to the right number. If your unlock code has a 0 in it you have to press the button once to get to 0. It starts with a dash (-). This doesn't count as the 0. For instance if your unlock code is 0873, you will press preset 1 once, preset 2 9x, preset 3 8x, and preset 4 4x. Once you have the correct number in the display press the "CD" button, and it will unlock your radio. If you didn't do it right, it will display "ERR1" before going back to the "CODE" display. Don't mess up more than twice. After the third failed try things get a lot more complicated. Good Luck Tim
Apr 17, 2011 | 1998 Mitsubishi Eclipse
Cannot maintain preset settings.
Do you have a fresh battery in the unit? Make sure your 'reset' button inside the battery case isn't 'stuck' on (push a little pencil in there).
Fresh battery, then do a reset inside the case, do a reset to factory settings, then try normal on and off with the switch and see if that fixes it or not.
Jul 25, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 29, 2010 | 1997 Audi A4
When i turn the ignition off i lose all radio presets. What wire needs to be live to keep the presets??
The Yellow wire is 12volt battery constant on after- market receiver heads.
Aug 16, 2009 | Car Audio & Video
Every time i turn my vehicle off i loose all my presets on my stereo
if this is not the original radio, then the wiring is wrong on your replacement. With the replacement radio, theres a wire that needs to be connected to Battery (+). this keeps presets and clock from losing memory
Jul 13, 2009 | 1993 Toyota Tercel
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
Sony CDX-GT100 CD Player Logo
280 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
