Question about X2 MG17R 17" LCD Monitor
My monitor just goes black on me. Sometimes I can turn it off and then back on and it might work for a while. Sometimes I can even get it to turn off except to unplug it.
  • 11,361 Answers
It may have dying power supply DC filter caps just like the rest of failed monitors here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 15, 2010
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
I have nec 2010x monitor, the monitor will sometimes work for a week or 2 or go black after a few days. The power light is on, and when I turn it off and on I can hear it turning on. The screen goes black...
Could be one of three things -
Backlight going out
Inverter card going out
or
PowerSupply
If you can hear a lcd turrning on then it's probably the power supply.
Jul 09, 2009 | Computers & Internet
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Keeps going out
check this monitor on another computer.If it is doing same then check power section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Jan 21, 2008 | Samsung SyncMaster 174V 17" Flat Panel LCD...
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
X2 MG17R 17" LCD Monitor Logo
98 people viewed this question
Top X2 Computers & Internet Experts
David Payne
David Payne
Are you a X2 Computer and Internet Expert? Answer questions, earn points and help others
