Question about Gateway HD2201 22" LCD Monitor
Monitor turns on shows gateway logo, show DVI symbol and then goes blank. I have have restarted monitor, computerm and change the cable with no effect. is this monitor shot. Cable works with another monitor hooked to same computer
  • 734 Answers
The answer is yes. The monitor's backlight is failing...almost gone.
Sorry,
Marcus
Posted on Sep 15, 2010
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
I have an AOC 22+ it is just a little over a year old (just out of warrantee) When you turn on the monitor and boot the computer the monitor will go thru its start up showing the AOC logo then it goes...
unfortunatly i believe the monitor may be dead. also check the connection on the monitor itself (the cable) some of these monitors are picky about which port is active dvi or vga there should be an option to change the input on the monitor itself from vga to dvi for the connection i hope that helps let me know!
Mar 14, 2011 | AOC V22 22" Monitor
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
Computer required restarting due to problems with mouse. Once computer was restarted gateway monitor would not work
Not enough information. Please describe any monitor activity when
you turn it on, do this while the computer is still off, unplug monitor, then
plug back in. It should start automatically, then show the gateway logo, then
go blank for several seconds, then show no input signal box, then shut down on its
own. If it fails to do this it is probably that the power printed circuit board
is failing, not delivering the proper power to the main board and/or the back
lamps. One can have this board repaired inexpensively by a qualified electronic
technician.
Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Have it repaired soon to avoid additional component failures
Dec 17, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Apr 28, 2007 | XFX GeForce FX 6800 (256 MB) Graphic Card
Gateway HD2201 22" LCD Monitor Logo
296 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
