Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Is it possible to get a replacement usb plug-in? My pins got bent beyond repair
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
If you have onboard USB, that is your USB is integrated into your motherboard, then you may not be able to remove them. However, don't loss heart, there are many USB add-on cards or even circuits which can be attached to your casing and then connected to the motherboard of your computer. Now if you can not get any of these, you still can get external USB connectors which conatins many USB connetors and you can attach that externally to your computer.
Posted on Sep 16, 2010
Usb port's pins are bent
Hi
usb sockets are normally pretty standard but without the make and model I could not be 100% certain.
https://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18957
regards
Jul 29, 2017 | Akai Professional Akai LPK25 Laptop...
XBOX had no power, so I found and repaired bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Jan 09, 2013 | Microsoft Xbox 360 Console
Lenovo USB port bent pins
The USB port/socket needs to be replaced it cannot be repaired.
It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Aug 25, 2012 | IBM Lenovo ThinkPad T400 (2767P6U) PC...
Any time I plug anything into any of the usb ports on my Advent roma 4001 my laptop switches itself off. Please help!
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines.
If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets).
Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc.
If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it.
Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem.
good luck
Jan 19, 2011 | Advent Computers & Internet
L have not yellow colour and blue in my screen,,,
assuming you have a VGA monitor, disconnect the video cable and inspect the pins. Check to make sure that the pins are not bent/crushed or missing (there should be 15 pins in 3 rows). You may need to look at both sides of the cable. If they are crushed/bent, replace the cable if possible. If not possible (because your cable is hard wired to the monitor), try VERY GENTLY to straighten the pins
Mar 07, 2010 | Computers & Internet
I moved my hi-fi system in doing this i bent one of the pins in the conection which conects my subwoofer to the control section I straightened the pin but after that the subwoofer would not turn on.
The pin you bent - was it the common RCA cable that carries the signal? It's replaceable.
Beyond that, we need specific information. Make & model of all involved components is always helpful.
Dec 01, 2009 | Electronics - Others
My broken usb socket
Purchase a PCMCIA USB Adapter. Will fit in the little card slot and add 2 or 4 more USB Ports.
Oct 20, 2009 | Dell Latitude D600 Notebook
Replaced batteries, mouse lights up but it does not work the curser. Any ideas
Get a new mouse. On my opinion I perfer a ball mouse then a laser type mouse because they just break fast.
Sep 30, 2009 | GE Wireless Optical Mouse
Bent pin in USB connector
call sandisk technical support. :D if its the pin of the player not the cable call them if its the cable try purchasing a new one there are lots of electronic shops out there.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
4 port belkin kvm
The things that usually go wrong with KVMs are bent connector pins (usually mouse or keyboard) or the switch itself. Inspect the mouse connector for bent or corroded pins. They are easy to bend and straighten, however, they will eventually break off if you do it often enough. If you find one that is bent the safest way to straighten it is by using a .7 diameter mechanical pencil. Remove the lead, and work the pin carefully into the pencil barrel. Once you have the pin inside the pencil gently straighten it by moving the pencil vertical. If it?s not a bent or corroded pin there isn't a whole lot else you can do other than try to get a warranty replacement or if its expensive enough, repaired.
Mar 20, 2007 | Belkin F1DK102P 2-port KVM Switch
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
