Question about Sony Televison & Video
There is a black border around the TV screen. Want picture on whole screen. How do I do that
nfandres
  • 168 Answers
SOURCE: KV-34HS420-Sony Tv
well based on ur info, ur tv has a prolem in power supply section, particularly regulation circuit. the regulator of the circuit seems to be mulfunctioning thats why insufficient voltage is coming out from B+ which in turn goes to high voltage circuits thats why the produced picture is insufficient. if this is very technical to u, have it check with a qualified technician.
Posted on Jan 16, 2007
tvtek
  • 1284 Answers
SOURCE: picture problem
The remote control for the TV sets 16.9, 4.3, 16.9 zoom etc... Use the two buttons I highlighted in yellow to change the screen size.
Posted on Feb 23, 2007
techman
  • 3130 Answers
SOURCE: Mitsubishi TV
Someone turned on the closed caption my friend. You will have to turn it off with the remote most likely. Since you thought we are fortune tellers and did not leave a model number, we cannot instruct you on how this is done. Most likely there will be a button on the remote that says captions or CC. Good Luck
Posted on Oct 05, 2007
  • 29 Answers
SOURCE: black border around games
Dear milly, so is it clear that this happens on all games or just some? tell me a little more about your system and games you play, I'll try and help. JLS
Posted on Oct 21, 2008
SOURCE: Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Posted on Dec 19, 2008
Picture does not extend to screen size
Hi check to c if U have a format button on the remote sounds like picture is in letterbox mode.,.good luck
Apr 16, 2016 | Televison & Video
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
Black border all around picture
is there a button labeled picture? if so press it (you might have to press it twice before it steps to a new aspect ratio, then once for every different aspect ratio until you get the one you like.
Jan 15, 2009 | RCA 32F531T 32" TV
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
ILo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
Mar 26, 2007 | iLO 2600 Television
Picture does not bleed to edge
this symptom is caused by a poor regulation in the power supply circuit. too low dc supply voltage will result to insufficient deflection, both vertically and horizontally. black borders appear around the raster. receivers generally use regulator in the main power supply to set the dc supply voltage at the value that will allow the picture to fill the screen with a little overscan. defective regulator can result in a small raster. most modern receivers today are using ic (integrated cirduit) regulator. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Feb 27, 2007 | Toshiba 27A43 27" TV
Televison & Video Logo
787 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
