Question about Samsung TXN3245FP 32" TV
Hey tech got a tough dog on this samsung model txn3245fp set was dead .h.o.t was shorted replaced it and the flyback after i did i had standby power as soonas i hit the power buttion hot shorted again cheaked r818 and r821 and all other componenets esr all the caps im begaining to think it might be the smaller flyback that is in tamdum with main fly dont know about b+ voltage ive not had it on long enouh to know is there something im missing thanks
  • Samsung Master
  • 5,807 Answers
To determine the cause, you might have to take out
the Horizontal Output Transistor.
There can be two points , where you can check
the Supply B+ to your Flyback
a ) Direct measurement on the Collector terminal
pin on the PCB ( after you have extracted )
b ) Direct measurement on the 200V line and post
the voltages.
Next after noting it down,
You will need to unplugged the yoke
You will also measure the voltages later
When you reinstall a new one ( But do not , yet
till I know the B+ you are having )
when these is connected and unconnected,
These is it for a while , while I would be suggesting
more, after I have known the B+ that your
Flyback is having.
These are your possible causes:
a ) capacitor parallel to the Horizontal Out Transistor
b ) bad yoke
c ) partially shorted Flyback
d ) fake Horizontal Output transistor
e ) Over driven Horizontal output due to
HDT and onwards to the osc.
( from the jungle IC )
f ) High B+
h ) High Voltage has exceeded its limit.
Posted on Sep 15, 2010
  • 1 more comment
  • Rommel Cana
    Rommel Cana Sep 15, 2010
    • here is where you can measure B+
    The unit will run, if there is no Hor Out Xsistor
    There will be about 215V on D411 if the
    Flyback
    oscillates
    ( H Out Xsistor connected of course )
  • Rommel Cana
    • you may have to check on these circuits
    if your B+ is higher than Normal
  • Rommel Cana
    • and you might also have the CRT Board disconnected
    from the CRT Socket , only when troubleshooting.
Service Manual
Here:
http://www.devicemanuals.com/guidedownload/Samsung-TXN3245FP-DynaFlat-HDTV-User%27s-Guide--TWpBMU5qQT.html
If it's the wrong one your looking for let me know.
Feb 04, 2009 | Samsung TXN3245FP 32" TV
LG CRT HDTV Dead no picture
if you have the b + acording the manual then you loose it
could be many things like the vert. circuit, the crt itself or
the flyback,
Aug 06, 2008 | Televison & Video
Dead set!
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jul 30, 2008 | Televison & Video
Wont startup
Youre flyback is defective.Its an easy repair your flyback is 145328551 which is no longer available but the substitute flyback is thats available at the following link and they provide free tech support with instant messageing so you can replace the flyback yourself. You need flyback 145328511 you can get it at this link with free shipping also. I use them all the time they are a good company with qiuality parts and free tech support.
http://servicemanuals.vstore.ca/
Jun 27, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Dead
Usually the flyback is bad on that model. You can get a replacement for under 50 dollars at the following link you need flyback RCA 259296 Heres the link they also provide free online tech support to all their customers .
May 08, 2008 | RCA D52W19 52" Rear Projection Television
Dead Set
No power, no sound. your tv is gona be dead set problem when they have no standby mode or standby ligth. need a repairman tech.
Apr 10, 2008 | Samsung CW29M64NS 29" TV
Help! Dyna Flat TXN3245FP
best to find repair tech.
Mar 16, 2008 | Samsung TXN3245FP 32" TV
Tv dead
please check flyback transformer for short
good luck
Nov 01, 2007 | Televison & Video
No picture or sound
take you tv to tech you have damaged your microchip and component in the power supply
Dec 20, 2006 | Samsung TXN3245FP 32" TV
Samsung TXN3245FP 32" TV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
