Question about Moen & One Handle Tub & Shower Faucet
Water is either hot or cold will not mix temps Model 100710 handle
  • 96 Answers
I believe this would be the cartridge behind the knob. Remove the knob and pull the cartridge out and do a little inspection. If you have hard water it is probably all fudged up. Change this part and your problem should be solved. Please rate! Thank you
Posted on Sep 15, 2010
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Installed a moen L82694cbn shower /tub combo. With the temp lever between the hot and cold settings the water backs up and comes out the showerhead along with coming out the faucet. With the lever all the...
I don't know if you had the mixing valve out or got it turned around but, try taking the handle off and operate the shower without the handle, in other words, turn the valve so the left side of the valve is now in the up position and just stick handle on and make sure you have your full range and hot and cold water. Two other possiblilities are, if you did not runwater before installing new valve, you may have gotten trash form the lines, plugging your valve. If you can't resolve the problem by mearly turning the mixing valve, you may want to remove it, make sure it's nott plugged and turn it 180 deg:
http://www.youtube.com/watch?v=J-SNBNijfQc
This is a video on how to remove the valve.
Jun 20, 2011 | Moen & One Handle Tub & Shower Faucet
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
I do not have a mixing valve on my boiler, will this create mixing problems? Sometimes it mixes ok. other times it is all hot or cold. I replaced the cartridge once. This system is only a couple of months...
If your posi-temp valve is working correctly this should not be a problem. Does your hot water temp. ever get extremly hot or just warmer? The way the posi-temp cartridge is designed if you have a large drop jn cold water pressure then the inside piston is supposed to slide to the hot side restricting the flow of hot water to a safe level.If the pressure on the hot side drops suddenly then the valve is supposed to restrict cold water flow.
If the temperature gets to a unsafe level you can adjust maximum hot setting by removing the handle. There is a allen head set screw on the bottom of the handle. Loosen screw and pull handle off. On the newer models pull off chrome sleeve from around valve body and slide outer geared disc off enough to seperate from inner gear. There are markings on disc with arrow pointing to h. or c. Adjust outer disc in the direction you want to adjust and slide it back so that gears engage. Each tooth on gears will change water temp. about2-3 degrees.Try it and readjust till you get the hot set point you want. One other thing you could do is install a small pressure tank on cold water line to compensate for pressure changes. Hope yhis helps you. Thanks
Nov 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
Not enough hot water in the shower even if I turn the handle all
Your valve has an anti-scald feature which automatically adjusts the water temp if cold water is diverted to another location, e.g., a flushed toilet, washing machine filling, etc. Most valves have an adjustment screw to allow you to set the temp. Since each manufacturer is different you'll need the manual or contact the manufacturers support. BTW, these anti-scald valves are being added to building codes in many parts of the U.S.
Mar 07, 2010 | American Standard Cambridge 5' Americast...
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
210 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
