Question about Acer Aspire 3690-2196 Notebook
START when i switch on the fan comes on for about 4 seconds then computer shuts down
    Genius:
  • 2,785 Answers
Check your ram and power supply
Posted on May 16, 2008
My computer starts up and then shuts down after seconds what do I do in order to swipe the whole thing out and fix it
This isnt a vehicle question but. If its a lap top then pull the battery and plug it in. If it stays running with no battery then the battery is junk. If it still shuts down then listen for the fan to come on during start up. If you dont hear the fan tbe computer may be getting hot teal fast and shutting down. Take it to a qualified tech to have it replaced before you fry tbe mother board
Nov 06, 2014 | Cars & Trucks
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Gateway MS2274 Laptop has a black screen and not booting. The power indicator comes on and all you hear is the fan and soon afterward will shut off; no hard drive LED. Tried removing the battery and...
Sounds like a severe hardware problem concerning your laptop's hard drive. I suggest you contact Gateway customer service to check on your warranty - your laptop is, simply put, broken. The best approach to repairing it is not to fix it yourself in this case.
Mar 13, 2011 | Computers & Internet
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
RE HP Pavillion ZE4800 Laptop When I switch on I here the fan start, the lights come on then it appears to shut down and re attempt to start again This occurs over and over and the PC never boots fully....
I have same notebook and similiar problem. Mine runs for 30 min then shuts off completely in like 20 seconds. I added a $10 usb powered laptop cooler pad and bingo, runs now for hours no problem. On all computers I know the cpu heat temperature has a threshold, if it goes too high it will shut off. I think my fan doesn't kick on fast enough to lower the temperature and cool the processor. On yours it may be a fan that doesn't work or is working at the wrong time and the circuit shuts off the system. Shouldn't be terribly expensive maybe $60 to repair from a good technician..good luck
Aug 15, 2008 | HP Computers & Internet
Computer STartup Problem
That is an impressive wait. You must be an OR LP to have tolerated that battery manipulation; hopefully the surgeons aren't up nights over the 3 lost insulated forceps.... It sounds as though the system is dissatisfied with the CPU fan speed or another power/cooling interface component (CPU over 90 centigrade, chipset over 95 centigrade, the power supply fan running, etc.) and thus shutting down immediately to protect itself. Do all those things check out, particularly in the BIOS power/cooling section? How about fan and power connections on your videocard being right and jumpered accommodatingly?
That is, you could connect tach fans on any spare 3-4 pin headers and see if favor comes your way. The system will spin them slowly once it boots and you enable automatic CPU/fan control (and power savings) settings.
May 11, 2008 | Computers & Internet
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
Processor fan
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Mar 18, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
My Processor is switched off after switch on the machine
The CPU cooler may be stopped up-- not working. That causes the processor to shut down se-f-protecting against excess heat. Check the cooling fan first.
Feb 17, 2008 | Intel Pentium 4, 3.06 GHz Pentium 4...
Acer Aspire 3690-2196 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
