Question about Samsung DV218AEW Electric Dryer
Is there anyway I can prevent sheets and blankets from getting wrapped into a ball as this prevents drying
  • 262 Answers
You can put one or two tennis balls in with them. There are also dryer "balls" that stores sell but tennis balls work too!
Posted on Sep 15, 2010
Hi i have samsung dryer it work fine but it doesn't dry sheets and blanket verry well??
This can be because blankets and sheets tend to absorb more water and do not dry well in a spin dryer. Check that your spin cycle on the washer is putting out enough spin to centripetal dry your blankets and sheets.
Feb 01, 2015 | Samsung Dryers
Close ball up and wont dry throught out
large blankets and sheets will ball up and you need to check often and un ball , has there been any work done on dryer /, If drum too fast cloths will ball up
Apr 06, 2014 | Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Clothes roll into a ball on matag dryer
THE DWADDER
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tightwad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets.
Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to
unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet. In order the fix this problem the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed into the dryer. Once the dryer is started the blanket or sheet will wrap around the device allowing a space to be in the center of the blanket or sheet. With the space that is created by the
Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to
unwad your blankets and sheets half way between the drying cycles.
The Dwadder will save you time and money. It can save up to 30 minutes off your drying time. This will save you energy. You will save time and worry less about your blanket or sheet not being completely dried when the drying process is finished. As an added feature the HDPE plastic ball opens to allow for a dryer safe fragrance to be placed inside the ball. This will reduce the use of dryer sheets.
We would love to have you as our customer. We know that the Dwadder will save you time, money and
lower the frustration of drying laundry.
For more information and
videos on how to assemble and use the Dwadder come visit us at
WWW. Defuturesolutions.com
http://www.defurturesolutions.com/
Jan 10, 2013 | Dryers
Two sets of sheets and the dryer wads the sheets in a ball and takes forever to dry. Then I untangle them and try again and still the same wadding up. Checked with other front loader owners and it...
I have Design a new solution it is the Dwadder.
Dwadder made from HDPE plastic. The Dwadder is the first ever Dryer Device that does dry your sheets and blankets faster! The Dwadder keeps your sheets and blankets from wadding up in the dryer. This will save you Time and Money when drying. Dwadder can cut your drying time up to 30 mins or more. Two sheets or blankets can be strapped to the Dwadder at a time to keep from wadding up in the dryer.
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tight wad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets. Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet.In order to fix this problem, the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed in the dryer. Once the dryer is started the blanket or sheet will wrap around the Dwadder allowing a space to be in the center of the blanket or sheet. With the space that is created by the Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to unwad your blankets and sheets half way between the drying cycles.
How to Use the Dwadder
Simply pull half of your blanket or sheet out of the washer. Then pull the silicone cord to slide the blanket or sheet between the silicone cord and the Dwadder. Slide the Dwadder to the center of the sheet or blanket then put your blanket or sheet in the dryer with the Dwadder attach to your blanket or sheet. You can use both silicone cords for two small blankets or sheets just don't place 2 blankets or sheet on top of each other or it will take longer to dry. For Video instructions please go to the website at www.Defuturesolutions.com or Youtube.
Apr 02, 2011 | Samsung DV337 Electric Dryer
When I dry sheets they ball up into a twisted wad and do not dry evenly. Do you have advice for this problem?
Lisa I find if you put sheets in with other items such as towels this can work to prevent them rolling into a ball and not drying evenly.
Jan 20, 2011 | Kitchen Ranges
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
Sheets and bedding get balled up in dryer and don't get dry.
DESIGNING FUTURE SOLUTIONS defuturesolutions com
Feb 02, 2018 | Samsung DV448AEE Electric Dryer
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Samsung DV218AEW Electric Dryer Logo
444 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
