Question about Dell Inspiron 2200 Notebook
My sound is very faint i cant get the volume to come up on the toolbar it says Volume Control Program not installed also when i try to adjust the volume under sound and audio device properties. SndVol 32.exe
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 22, 2010
Where is adjuystment page for audio
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps you
Mar 22, 2012 | Logitech Audio Players & Recorders
Sound is very faint and distant
hope this helps
I can't barely hear sound from my Gateway laptop speaker m305crv? only headphones and extra speakers work! PAUL TUMINO
1. Do you have an external volume control on the side? If so adjust it.
2. Do you have a speaker symbol in your lower right hand toolbar? If so, right click on it, go to open volume control, and adjust the slides.
3. No speaker in the toolbar? Left click START, choose CONTROL PANEL, find the ikon that says SOUND AND AUDIO DEVICES, double left click it and adjust the volume.
Mar 25, 2011 | Computers & Internet
I just connected my Logitech lS11 speakers. How do I tell my computer that I now have these? When I click on my volume icon in the tool bar to adjust my volume does not work? thank you
Windows does not detect specific models of speakers. I would adjust your Windows volume all the way up and then adjust the sound on your volume knob on speakers. This way the sound volume is easier to adjust on speaker than using the volume control in the toolbar.
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
How to change soubd tone on acer aspire one
  • Find out which audio controller is installed on the system. Go to the "Control Panel" and double-click on the "Sounds and Audio Devices" icon. Click on the "Audio" tab to see what is listed for the default device for sound playback.
  • Download driver and software updates directly from Acer's website (see Resources). Save the files to a folder, and then run the setup program to install the software.
  • Download and install a new software driver for your laptop's on-board audio controller. Many audio controllers in Acer Aspire laptops use the AC97 Audio Codec driver. Go to the Realtek website and click on the "Downloads" tab to see available software (see Resources).
  • Adjust the sound using the Master Volume setting. Right-click on the audio icon on the toolbar and select "Open Volume Control." Use the Master Volume and Wave input settings to adjust the volume of the audio that is being heard.
  • Use a software program such as the Realtek Sound Effect Manager to control and adjust the laptop's audio settings. There should be an icon on the desktop or toolbar, but you can also find the program in the Control Panel as well. The program contains an equalizer with presets to choose from as well as mixer and audio I/O options.
Feb 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Audio controler problem cant hear any voice from my pc
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 08, 2011 | Intel D845GVSR Motherboard
Cant adjust microphone
Make sure your webcam mic is set as default
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
Volume control program installation
go to the control panel, open the sound and audio.
check the box in front of "place volume icon in the taskbar", under the device volume, in the volume tab page.
Mar 17, 2009 | Microsoft Windows XP Home Edition
Volume icon
Open control panel, sound and audio devices and put a check in the box that says "place volume icon in toolbar"
Then you can open this and turn on or off mic and other sound inputs withthe advanced settings
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Inspiron 2200 Notebook Logo
78 people viewed this question
Alun Cox
